RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   maximum st (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/8251345-maximum-st.html)
jasonaka 12-16-2008 11:21 AM
maximum st
does any body has a maximum st i just got one and its harad to start can so one tell me how to deal with that
jasonaka 12-16-2008 02:39 PM
RE: maximum st
i bought nenw gas it still does not start
i bought a glow plug and it still dont start
i am now wonder if it is getting current from the igniter
help pleaseee
Barber420 12-16-2008 02:52 PM
RE: maximum st
Take your igniter and put a glow plug in it and see if it glows, and if it does, does it glow brightly. I'm guessing your engine isn't broken in yet. Engines can be VERY hard to get running until they are fully broken in. Do you have a pull start on this truck? What size engine is in it? What brand and nitro % of fuel are you using? Have you done any adjustments to the idle, low speed needle, or high speed needle? It may help to use a hairdryer to warm up the engine a significant amount before trying to start it. This may help.
jasonaka 12-17-2008 08:40 AM
RE: maximum st
i did put the plug in the igniter but i dont seem to see anything as such
yes it does have a pull start, the engine is a torq16, fuel i use is byrons original 20%
ok as pertaining to the needles the adjust i did was from the one that came in the manual so i followed that
but i dont know if the igniter is bad
do they usually go bad and how can i check if it is it thats not working
jasonaka 12-18-2008 10:59 AM
RE: maximum st
ok guys the engine is alive the igniter was way bad
but now a other problem lives the rim on the back right side melted today the nut that hold it got really hot so the rims is dead
anyone know the size of the rim
brando44 12-18-2008 12:01 PM
RE: maximum st
it is a standered 2.2 truck rim that mounts to a 12mm hex nut
i have the same truck mine a the st pro with a os 18 cv-r
