What is the difference in these two buggies?
I see that Himoto sells the HI8101 and the HI8102.
The HI8101 is $139.99 and the HI8102 is $173.99 But the specs are the same(if I remembor correctly) What is the difference in these two buggies? Nevermind.... I found the HI8101 is a single speed while the HI8102 is the 2-speed. My bad! |
RE: What is the difference in these two buggies?
8101 is a single speed with c hub suspension and a vx .18
8102 is a 2 speed with c hub suspension and an sh .18 or infinity .18 (better engine) |
Gotcha!
If you want a buggy that is super durable, fast, reliable trans, check out the mxb: http://server.sohouniverse.net/~himo...hp?id=589&=SID
I dont have either buggies...but I do have a mtr-3....the megap buggy would be a far better buy...although its a bit more, you get a better buggy
ORIGINAL: HimotoRacingUSA If you want a buggy that is super durable, fast, reliable trans, check out the mxb: http://server.sohouniverse.net/~himo...hp?id=589&=SID ohhhhhh the possibilities! |
JP...
The MXB Buggy is SWEET! I have the 3 diff model (MXB-3) It's Heads n Tails above those oldstyle HSP cars..... |
im with firebird78. i had the MTR-2s and it was GREAT... i got the MTR-3 so i sold the 2 speed..... and it was SWEET.. you cant go wrong with a MegaP Himoto...
| All times are GMT -8. The time now is 06:59 AM. |
