help please!
i just baught a new steering servo for my HPI firestorm i got the Futaba S3305 an im sonfused on installing it i can find any intructions on how to install it any help would be awsome
RE: help please!
What do you need to know? If you have the book that came with it go to page 29 and their is a parts breakdown that shows you all the parts and how they are assembled.Basically just pop the arm off with a pair of needle nose and unscrew it and change it out.Let us know how you make out or if you need more help.
RE: help please!
take the servo arm off, remove the old servo, plug the new servo in and power it up so that it centers while making sure all the trims are centered. install the servo then plug the servo arm back in so that the wheels point straight. use sub trim to get the car driving straight.
RE: help please!
i got that all fixed up and now my engine wont start , when a crank on it, it makes a bogged down type of sound instead of a high pitched cranking sound im not sure what the probelm is could it be flooded , another thing when testing glow plugs should they light up all the way to the top because mine look like everything lights up but one the top part of the last ring.
| All times are GMT -8. The time now is 03:23 PM. |
