Clutchbell and Spure Gears
hi,
I'm looking for a Clutchbell and metal spur gear that fit in a mt2. Someone who knows? Can someone help me? Thank you |
RE: Clutchbell and Spure Gears
a 12t or 13t clutch bell and a 52t spur is what i know will work on a MT2. i just recently tried to put 15/52 and the mesh was far too tight. the manual for the MT2 t-15 says 12t clutch bell.
You can run a 15/52 but you need to widen the mounting holes a little with a dremel. It works fine after that. But it depends on your engine. If it doesnt have enough power 15/52 is going to dog off the line. 13/52 works well with most engines
