RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   what is a head button??? (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/8517197-what-head-button.html)
cadillac98 02-25-2009 01:54 PM
just wanna make sure this is what i need b4 i order it..i was tightening down my glow plug and went too far..i stripped sumthing...i bought a new plug and it didnt tighten either..after removing the cooling head i see where the plug screws into..this is the head button right?
Argess 02-25-2009 02:00 PM
RE: what is a head button???
yep...sounds right to me. Some engines don't have one.....1-piece head. Those with 2-piece heads.....pat 1 = heatsink, part 2 = head button (that holds glowplug)
xt2nitro 02-25-2009 02:08 PM
Yes that would be the head button. Once I stripped the head button by screwing the glow plug in at an angle (which I did not know at the time) until I tried to screw another glow plug in. I find it easy to turn the car on it's side so you can clearly see that you are screwing it in straight and not at an angle. Go easy on the head button. It is easily stripped.
Sugafree 02-25-2009 02:13 PM
http://images.amainhobbies.com/image...e/losr1021.jpg
Brett185 02-25-2009 04:57 PM
I personally haven't stripped one, but just for future reference, if I do happen to strip on in the future would it be possible to run a tap through it without causing damage? And yes I know I would have to remove it first...lol....
Foxy 02-25-2009 05:16 PM
The trouble with stripping head buttons and plugs is that you get tiny shards of metal in the cylinder. Make sure you strip and thoroughly rinse the engine before using it again.
PS. Don't try retapping it.
cadillac98 02-26-2009 12:28 AM
i was thinking about that too...i have the sh18..is it difficult to get inside it to rinse it out? do i use water?
Foxy 02-26-2009 03:10 AM
Use nitro fuel to flush it, it's expensive but better than using wd40. You will have to completely disassemble the engine. Never let any water anywhere near your engine internals.
joeyhatch11 02-26-2009 06:40 AM
Water big NO NO. Hahaha Fuel is always the best option or WD-40 for backup.
cadillac98 02-26-2009 11:34 AM
ok..thanks
