throttle servo problem
Whenever i have my car running the throttle servo keeps twitching. And once i give it throttle the arm stays where its at. Sometimes it moves whenever i move the steering servo. what should i do?
check the wires.
make sure they arent pinched,frayed, or anything like that. check the connect to the servo and swap the throttle/steering servo and see if the problem follows to the swap. if so it might be the rx. did you run through a lot of puddles? water hurts ofcourse. check the linkage to make sure its functioning properly. |
nah no puddles. It was running fine the last time i ran it.
swap it out to another servo, anything electric breaks too! mabe it's just it's time :(
low batteries in either the transmitter or in the car will cause this.
i swap the servos for throttle/steering and it was the same thing. I think it might be low batteries in my transmitter but the lights not blinking.
Get a chargin then! don't wait for the blink
Mine does it all the time.. . brand new servos but old receiver.. but it fine when running.. so i'm not to worried..
I would only worry about it when it ****s up running...!! |
is probably the batteries, mine did this aswell and batts were the problem
dude you didnt even check your batteries befor eyou came in asking why somethign dont work right?
come on dude that #1 thing to check in that area. |
dude, sorry even before this happened i only ran it 3 times with "new" batteries so i didnt think they would run out so quickly.
My NTC3 does the same thing but I can not notice it on the track.
| All times are GMT -8. The time now is 06:27 PM. |
