Spring rates
Are spring rates for losi springs as simple as they look? The higher the number the more weight it takes to compress the spring. So a 5 would be a stiffer spring than a 4?
RE: Spring rates
This is for 10th scale right?
FRONT BUGGY SPRINGS Losi Part # A-5128 2" Spring 2.5 Rate (Red) A-5129 2" Spring 2.9 Rate (Orange) A-5130 2" Spring 3.2 Rate (Silver) A-5132 2" Spring 3.5 Rate (Green) A-5134 2" Spring 3.8 Rate (Blue) A-5135 2" Spring 4.1 Rate (Black) REAR BUGGY & TRUCK (front and rear) SPRINGS Losi Part # A-5146 2.75" Spring 1.6 Rate (gray) A-5147 2.75" Spring 1.8 Rate (White) A-5148 2.75" Spring 2.0 Rate (Yellow) A-5150 2.5" Spring 2.3 Rate (Pink) A-5152 2.5" Spring 2.6 Rate (Red) A-5154 2.5" Spring 2.9 Rate (Orange) A-5156 2.5" Spring 3.4 Rate (Silver) A-5158 2.5" Spring 3.7 Rate (Green) A-5160 2.5" Spring 4.1 Rate (Blue) |
RE: Spring rates
ORIGINAL: Chris_RC This is for 10th scale right? |
RE: Spring rates
The higher the number, the stiffer the spring or the harder it is to compress.
RE: Spring rates
ORIGINAL: OvalRacer99 The higher the number, the stiffer the spring or the harder it is to compress. |
| All times are GMT -8. The time now is 10:20 AM. |
