RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   problems with CVDs (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/913532-problems-cvds.html)
nitroman88 06-30-2003 11:58 PM
problems with CVDs
I had a pin come out of one of my CVDs while in a heat race, anyways it didnt come out all at once and acted like a saw which destroyed my Arm. How can I prevent this from happening again?? I have heard people using shrink wrap but does it hold good and can I get it at my lhs??
thanks
jswinkos 07-01-2003 12:54 AM
problems with CVDs
dremel a notch in the pin where the setscrew will sit and use loctite on the setscrew. Then, if you want, put heatshrink around the area where the pin is. I personally don't use heatshrink because once you dremel a notch, it won't come out.
nitroman88 07-01-2003 01:27 AM
problems with CVDs
Wouldnt it be kinda hard to get the slot right in the center?? also would that make the pin weak?
jswinkos 07-01-2003 04:29 AM
problems with CVDs
i took a fine tip marker and marked where to dremel. You don't have to dremel much, just enough for the set screw to mate up.
here's a link to how to do everything
http://www.hpiracing.com/walkthroughs/rebuild-cvd.htm
whitexj 07-01-2003 12:58 PM
problems with CVDs
Have you seen those Tebo rings from Jareds RC10GT in RCCA. Those look sweet and I think they would work good. If you like cvd's stay w/ them and try what jswinkos said, it works awsome. I have gone back to dogbones b/c thier way cheaper and never break!
ZIZI 07-01-2003 01:54 PM
problems with CVDs
I use these socks. Their rubber things that go over that area and they prevent teh pin from coming out. Im just not sure where I got them though.
thanks
ZIZI
