what brand nitro fuel?
what is the best brand nitro fuel for me, 20%.
im going to have a .12 rear exhaust racing engine. A fresh tuned pipe, motor saver filter, lightweight flywheel etc. expensive stuff, so i want the fuel that would give it consistent tuning, temperatures, and lubrication, you know what i mean. i heard o'donnels a good brand. |
RE: what brand nitro fuel?
Gen 2 Its been good to my .12 i have been able to lean my engine more while keeping a good temp with gen2 then with other fuels
O'Donnell is okay but very toxic. Nitrotane is good. Byron gen 2 race is IMO the best. Always get the race blends, and NOT the RTR crap!
On a side note, why did you get the motor savers air filter? They dont work that wel-they restrict air a bit, and it doesnt really extend the life of your air filter. If you want to get something like that for alot cheaper, go to walmart or some place like that and buy some women's stockings and use the closed-end section of it. Very cheap and works fine if thats what you want. |
I'm no expert on fuels but I've always had good luck with O'Donnells race fuel.
i was looking at maybe using the same brand. using the hpi branded fuel made by wildcat fuels. these any good? maybe since its the same brand that made my engine it'll run just how its supposed to. also, any tips on extending engine life? i wanna last through atleast 5 gallons on this engine.
ORIGINAL: cannouu i was looking at maybe using the same brand. using the hpi branded fuel made by wildcat fuels. these any good? maybe since its the same brand that made my engine it'll run just how its supposed to. also, any tips on extending engine life? i wanna last through atleast 5 gallons on this engine. Do the heat cycle method for breakin, start race tuning at tank 15, dont run lean or overtemp, and you should be just fine. |
If you can find it in your area try Maxy's Fuels. Awesome fuel I won't use anything else. I have run Byrons, BlueThunder, Cheap Traxxas, and now I run Maxy's. Cool temps and lots of power. Already have 2 gallons through my OS .21 TM and the motor has great pinch and compression. Also side note. I have run MotorSaver air filters on all my RC's and they work great. Never had an issue with them.
O'Donnell's race blend for me, never had any issues running it.
trinity platinum, ive had good luck with it so far ... wanting some gen2 but the lhs cant/wont get it :/
What's too much oi???. 18% is good. 12% is bad! Nothing wrong with widcat fuel. Stay in between and you should be fine.
ORIGINAL: Chris_RC ORIGINAL: cannouu i was looking at maybe using the same brand. using the hpi branded fuel made by wildcat fuels. these any good? maybe since its the same brand that made my engine it'll run just how its supposed to. also, any tips on extending engine life? i wanna last through atleast 5 gallons on this engine. Do the heat cycle method for breakin, start race tuning at tank 15, dont run lean or overtemp, and you should be just fine. |
ORIGINAL: rendezvous944 What's too much oi???. 18% is good. 12% is bad! Nothing wrong with widcat fuel. Stay in between and you should be fine. ORIGINAL: Chris_RC ORIGINAL: cannouu i was looking at maybe using the same brand. using the hpi branded fuel made by wildcat fuels. these any good? maybe since its the same brand that made my engine it'll run just how its supposed to. also, any tips on extending engine life? i wanna last through atleast 5 gallons on this engine. Do the heat cycle method for breakin, start race tuning at tank 15, dont run lean or overtemp, and you should be just fine. Alot of synthetic oil will cause extremely high temps, horrible performance, harder tuning, less engine life, and will just be fusterating to work with. You want fuels that have a high castor blend like Byron which has good protection if you run your engine over 350+ degrees. Trinity Platinum is also good fuel like MCSRacing said. I tried the 20% and I liked it. That has 8% oil with high castor. |
Maxys Fuel has 10% Castor Synthetic blend. Engine runs great no dyes in it so the fuel is clear and has tons of power. I agree. Too high a percentage in oit will give poor performance. Why do you think so many do not like the Traxxas fuel. High oil percantage and the engine runs super hot. Not to mention to much oil will also cause the one way bearing to slip. I found Maxys fuel on AMAINHOBBIES.com but they want some crazy prices. $82.00 for a gallon of 20%. I get 30% from my LHS for $32.00.
try find some sort of 16% works well with most .12 engines
ORIGINAL: quietnas1 Maxys Fuel has 10% Castor Synthetic blend. Engine runs great no dyes in it so the fuel is clear and has tons of power. I agree. Too high a percentage in oit will give poor performance. Why do you think so many do not like the Traxxas fuel. High oil percantage and the engine runs super hot. Not to mention to much oil will also cause the one way bearing to slip. I found Maxys fuel on AMAINHOBBIES.com but they want some crazy prices. $82.00 for a gallon of 20%. I get 30% from my LHS for $32.00. |
this is the hpi thats made fom wilcat fuels. http://www3.towerhobbies.com/cgi-bin...LXTT04&P=7. it says 14% synthetic/castor blend. 99.9% pure nitromethane.
oh yea. im not so much into performance. as long as i can get it over 50mph. im willing to richen the fuel to make the engine last longer. also wanna do perfect engine break in. Im doing everything to extend the life, like sealing the engine (non-ps), fuel... Oh and what lubrication is good to put on the piston oil ring whenever i rebuild, silicone shock oil? i tried it and it gave me better compression because of the thickness.
ORIGINAL: cannouu oh yea. im not so much into performance. as long as i can get it over 50mph. im willing to richen the fuel to make the engine last longer. also wanna do perfect engine break in. Im doing everything to extend the life, like sealing the engine (non-ps), fuel... Oh and what lubrication is good to put on the piston oil ring whenever i rebuild, silicone shock oil? i tried it and it gave me better compression because of the thickness. The oil seems a bit high with the HPI fuel. What other fuel does your LHS stock? Or are you willing to buy online? If so, get the Byron 20% race from amainhobbies.com. |
Only fuel I ever had trouble with was Sidewinder Backyard Basher. Engines run hot and are touchy to tune. I do belive it is from too much oil. Sidewinder Race or Blue Thunder Sport seem fine to me, alhtough I have no idea how they compare to other fuels. Most are probably fine.
ORIGINAL: Chris_RC ORIGINAL: quietnas1 Maxys Fuel has 10% Castor Synthetic blend. Engine runs great no dyes in it so the fuel is clear and has tons of power. I agree. Too high a percentage in oit will give poor performance. Why do you think so many do not like the Traxxas fuel. High oil percantage and the engine runs super hot. Not to mention to much oil will also cause the one way bearing to slip. I found Maxys fuel on AMAINHOBBIES.com but they want some crazy prices. $82.00 for a gallon of 20%. I get 30% from my LHS for $32.00. |
ORIGINAL: cannouu oh yea. im not so much into performance. as long as i can get it over 50mph. im willing to richen the fuel to make the engine last longer. also wanna do perfect engine break in. Im doing everything to extend the life, like sealing the engine (non-ps), fuel... Oh and what lubrication is good to put on the piston oil ring whenever i rebuild, silicone shock oil? i tried it and it gave me better compression because of the thickness. |
16%-18% oil is fine for backyaqrd bashing. The right brand fuel makes all the difference. I have use wildcat 18% oil no problems. engine runs cooler than Omega fuel. Less oil is for racing. You will spend more time rebuilding with less oil.
ORIGINAL: rendezvous944 16%-18% oil is fine for backyaqrd bashing. The right brand fuel makes all the difference. I have use wildcat 18% oil no problems. engine runs cooler than Omega fuel. Less oil is for racing. You will spend more time rebuilding with less oil. |
Look good example. I am a basher first of all. When I had my 3.3 in my Jato I was using Traxxas fuel 33%. It has a high oil content. My engine used to run mega hot even in a rich setting. If I leaned just a bit smoke would steam up from the head. I started using Maxys 30% which has a lower oil content and my 3.3 had a lot more power and ran a lot cooler on a rich setting than with the Traxxas fuel. Also I am able to lean my engine out a bit for all out speed and still not over heat. This isn't to promote the fuel I use but to show you that a fuel with 8% to 12% oil content is ideal for racers and bashers alike and improves engine life.
personally i would go with byron!
As has been said, in nitro engines too much oil will raise, not lower, the operating temps of the engine. It has to do with several factors, including the make up of the oil. But a lot of the increased heat is from the fact that residule oil retains heat and does not disapate it well. If you have soo much oil that it is not mostly burnt off in the combustion of the fuel then the remaining oil will retain the heat and cause the engine to run hotter.
Counterintuitive I know, but true none-the-less. |
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
