batteries
What kind of batteries do you guys run in your remotes and in your nitro truck for servos? Rechargables or throw aways?
RE: batteries
Energizer AA's
I like the ability to not have to worry about planning when I want to run :D. |
RE: batteries
That's what I do now also. Just didn't know if it would be worth going to rechargables.
RE: batteries
me no
I got 3 Nitros and my one I used the most still has its batteries from last season and there going strong. Only time I had to replace them was when I forgot the receiver on over night [X(] (almost did it last night) But I also use D-cell glow plug warmers also. My controller also lasts for over 10 hours on one set of batteries. I forgot it on for 7 hours and used it over 5, and its still good according to the voltage monitor built into the controller I'm estimating they will be good for another 5 hours. |
RE: batteries
Energizers or Duracells in the Transmitter and LIPO in the truck.
Nicad or Metal hydrydes for the starter or an 8$ throw away. In some cars aa energizers for the reciever or duracells.All alkaline. And in my daughters ride-in remote 12v piddlefoot modified land criuser its a 5.4amp hour lead acid battery ! Came with a 1 amp hour battery and crap motor etc. l had to give it suspension to handle the extra power, but now were on the verge of needing a new gear box !She grinds sometimes ! Kid loves it but ! lm gunna do the front suspension next ! |
RE: batteries
so far I only run one controller with rechargeable AA batteries. Venom 2400mah nimh AA's in a 3ch 2.4ghz Futaba transmitter. I like them. They've outlasted any alkalines that I've put in there prior to using the rechargeables. I usually don't have to plan when I'm going to run because there's usually plenty of charge left in the batteries. When it's time to recharge, I spend the hour(?) to recharge them and I'm good to go for another couple weeks (depending on how much I use it).
RE: batteries
thanks
| All times are GMT -8. The time now is 12:02 AM. |
