RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   engine troubble (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/960603-engine-troubble.html)
cbliton311 07-15-2003 07:55 PM
engine troubble
i recently got a brand new street force gp and i dont live by any other racers so i have only sen whats on the internet, i am halfway through the breakin process but when i start my car the wheels spin and it wont idle, i have messed with the steering trim but they wont stop completely, i am shure it is some smalldetail i am over looking but i dont know also i cant stop it even with the breaks it just shuts off, any one know any solutions or even direct me to what i could look at and replace to fix i just want to know the proplem this is my first nitro car and i am frustrated please help :mad:
VecoRacer 07-15-2003 09:27 PM
engine troubble
You need to unscrew your idle screw (anti-clockwise), i think, otherwise you got to make the throttle mechanism shorter?
dan1220 07-15-2003 09:39 PM
engine troubble
I would do what VecoRacer said. Unscrew the idle screw. take the airfilter off, and look int the carb. make sure all of your radio gear is on. the gap should be about 1mm.
cbliton311 07-15-2003 10:55 PM
engine troubble
but i cant even start it on the ground will that really help? and how do i make the throttle thing smaller? would making the brake lever longer help?
dan1220 07-15-2003 11:13 PM
engine troubble
if you cant start it, how do you know that the wheels spin? Im confused.
dg2b 07-16-2003 04:07 PM
Re: engine troubble
Originally posted by cbliton311
--8<-----8<-----i have messed with the steering trim but they wont stop completely, i am shure it is some smalldetail i am over looking but i dont know also i cant stop it even with the breaks it just shuts off, any one know any solutions or even direct me to what i could look at and replace to fix i just want to know the proplem this is my first nitro car and i am frustrated please help :mad:
If your car wont idle when on the ground and when it is elevated, the wheel spin, to me that is a sign of a burnt clutch.
Can you spin the clutchbell freely? Your steering trim has nothing to do with this issue. Try the throttle trim or what others stated, use the idle screw to adjust and when you apply the brakes, your carburator still has an opening. The carburator opening is controlled by the idle screw, not by the throttle trim.
NitroFreak 07-16-2003 04:59 PM
Re: Re: engine troubble
Can you spin the clutchbell freely? Your steering trim has nothing to do with this issue. Try the throttle trim or what others stated, use the idle screw to adjust and when you apply the brakes, your carburator still has an opening. The carburator opening is controlled by the idle screw, not by the throtlte trim.
Yep.. If your wheels spin and you can't start it when it is on the ground you melted the clutch to the clutch bell. This is cause by using the brake to keep the car in one spot when idling. Your car should be able to roll freely when idiling.
cbliton311 07-16-2003 10:31 PM
engine troubble
ok my clutch is the problem. it was so melted together i didnt realize it wasnt sopous to be thet way thanks. are there any hop up clutches that would reduce a problem like this next time or that look cool?
dg2b 07-16-2003 10:48 PM
engine troubble
I believe you can use a racing clutch from HPI. Can't remember the HPI part number off hand.
cbliton311 07-17-2003 01:27 AM
engine troubble
so what things would i need to buy the clutch, bell , anything else? i ask this because when i take it apart i wont know what bad sighns to look for on the parts, seeing how it was an rtr
NitroFreak 07-17-2003 12:25 PM
engine troubble
You shouldn't need a new bell. But I would get a racing clutch. But before you melt that one make sure you adjust your idle so it it barely inding. the carb should only have a 1mm opening. when the car is started you should be able to move it back and forth without any resistance.
whitexj 07-17-2003 01:16 PM
engine troubble
how much are clutches for lets say the mach 15? isnt it only the clutch shoes you gotta buy?
dg2b 07-17-2003 01:31 PM
engine troubble
Sometimes when you melt the clutch, more likely, you may have affected the bearings also. Best bet is to check first before buying/ordering.
You might need the following:
- racing clutch towerhobbies part #lxlw03 $13.99
- clutch bell bearing towerhobbies part #lxm766 $5.99
rc10gtplusR2R 07-17-2003 02:27 PM
engine troubble
i don't get the 4in1 how douse it work and what do you have to get to install it
dg2b 07-17-2003 02:32 PM
engine troubble
I am not sure what "4in1" means but if you have a clutch (not centax), the hpi racing clutch will most likely work. Most all of the flywheel have two prongs. Use two of the holes opposite to each other. The extra holes in the clutch are for tuning purposes. Using different hole position to adjust clutch engagement.
rc10gtplusR2R 07-17-2003 02:37 PM
engine troubble
the hpi 4in1
http://www2.towerhobbies.com/cgi-bin...03&FVPROFIL=++
how do i install do i need a lot of stuff or will it go right on like a stock bell
dg2b 07-17-2003 02:42 PM
engine troubble
Your link points to the hpi racing clutch I mentioned (towerhobbies part #lxlw03).
The two parts I mentioned above should be the only two parts you need.
rc10gtplusR2R 07-17-2003 03:16 PM
engine troubble
where do u put that part lxm766 i dont get it sorry never had a hpi 4in1 before for the money is the worth it if i know i'm not going to race just play around
dg2b 07-17-2003 04:26 PM
engine troubble
The lxm766 is for your clutch bell. This is the part that most RTR kits will put a poly/plastic part in. If you melted the clutch, the plastic part will most likely warpped. Having this type of clutch will get your playing around more fun.
Sometimes, clutch is the most overlooked part of tuning a car. This is the clutch I used before prior to me going to centax.
rc10gtplusR2R 07-17-2003 04:47 PM
engine troubble
do u have a pic of the centax
dg2b 07-17-2003 05:43 PM
engine troubble
1 Attachment(s)
There are few cars that can't take the centax clutch. Centax clutch also requires SG crank.
rc10gtplusR2R 07-17-2003 07:55 PM
engine troubble
what kinda car is that i dont think i can put that kind on a rc10gt can i
