losi t ten battery, receiver,transmitter no start
GA
I have a losi t ten I didn't like the 7.4 1000mah 10c lipo died to quickly. Found a 7.4 1300mah 15c that fits battery box. I put it in and it started. Next I took out the servos and replaced with hi tec 5685mh high voltage servos and they work fine but now won't start .I bypassed remote ross onboard starting system. I hooked battery directly to starting motor and it turned over so did I ruin module or hook up wires wrong to receiver heres what I did, I hooked throttle servo to thr port on receiver. Hooked steering servo to str port. Hook wire around engine to temp port. hooked speed senser wire to rpm port. Hooked unknow wire to bind/rs port where did I go wrong Fred
