KOPROPO FET/ICS?
RE: KOPROPO FET/ICS?
FET and ICS are different technologies and have nothing to do with each other. Neither technology requires the other. KO produces servos with both, one or the other, and neither.
FET stands for Field Effect Transistor and describes the type of transistors that power the servo. Electronic speed controls use MOSFETs in them, which is simply another type of FET transistor.
ICS stands for Interactive Communications System and is a computer-based system for setting your ICS components. You download and install the software, connect your radio to the computer, and start programming.
