Servo Problem??
CA
Servo Problem??
hello,
i had just replcaed the gears in teh servo(becuase the old ones had broken teeth) and now nothing happens when i turn the levr on my radio. so i oppened it back up and right when i turn the radio on the main gear just spins out of control. and when i turn the radio wheel nothing happens? is there somthing wrong with the radio or servo? Does anybody knows what is happening and know how i can fix it? please help.
Dj
Dj
IL
RE: Servo Problem??
Are you sure it is the servo and not some adjustment made accidently to the trim? Did you maybe jostle one of the knobs on the transmitter? or does the steering just not respond when you input a command, or what i mean is do the tires return to equilibrium (center) when you quit turning the steering wheel.
CA
RE: Servo Problem??
i figured the problem was the gear was missing teeth, everytime i hit the ground hard i break servos(seeing that my entire front end is aluminum)
