RC Car Radio Equipment Discuss specific topics related to RC car radios. For general or non rc car specific radio topics please see our regular radio discussion forum.
spektrum built-in failsafe
Old 04-14-2005, 06:29 PM
mplst
Default spektrum built-in failsafe
i've never used a failsafe before and was wondering what a respectable response time for it to kick in? my spektrum kicks in just under a second. one second seems like a long time if you got a run away.
Old 04-16-2005, 12:40 PM
kctay
Default RE: spektrum built-in failsafe
If I turn off my radio, my Spektrum failsafe kicks in immediately, no lag
Old 04-17-2005, 12:14 AM
bentgear
Mine takes under a second, but there is a noticeable delay. I think first it is making sure it cannot regain the signal.
Ed M.
Old 04-19-2005, 08:38 AM
mplst
my failsafe will kick in instantly if i turn on the receiver without the transmitter being on. it's when i have both turned on and then turn off the transmitter that i get the delay. i have 2 receivers and that seems to be the case with both. how about you guys?
Old 04-19-2005, 09:13 AM
bentgear
Same thing here. Always starts up in the failsafe settings til it aquires the signal from the transmitter.
Ed M.
Old 04-20-2005, 02:17 AM
Galifrey
Galifrey's Avatar
fail-safe takes just under 1 second on both mine as well...
It is a little slower than my HRS/PCM rx's, but rather that than a false failsafe...
Old 04-20-2005, 08:16 PM
Savagenut
I am not sure on how to set the fail safe on the spektrum. I did the binding, but when I shut it off, the throtle servo moves back just a bit, but not enough to cause the car to brake.
Old 04-20-2005, 10:43 PM
bentgear
When you get to the turn the radio on part of the binding process hold the wheel and throttle where you want them to be during a failsafe engagement. In my case I used steering straight ahead and a slight brake application.
After you get the radio setup to the model (or the other way around if you prefer) is the right time to go in and rebind setting failsafe. If you do it first thing chances are it will not be right after the setup process.
Ed M.
