RC Car Radio Equipment Discuss specific topics related to RC car radios. For general or non rc car specific radio topics please see our regular radio discussion forum.
ATL ?
Old 08-04-2005, 08:05 PM
R3k0
R3k0's Avatar
Default ATL ?
i just got a 3pk and i understand ATL to limit the throttle
but it only seems to limit the brake ?
what am i missing here ?
tia
Old 08-04-2005, 08:26 PM
Nitroaddict
Nitroaddict's Avatar
Default RE: ATL ?
squeeze and hold the trigger when adjusting the ATL on throttle.
Old 08-05-2005, 04:46 AM
R3k0
R3k0's Avatar
Default RE: ATL ?
dont understand ? ive tryed what u say and there is no difference
the manual does say that its for brake only ? :/
Old 08-05-2005, 09:05 AM
P2gee
Default RE: ATL ?
ORIGINAL: R3k0
Your manual is correct ....ATL increases/decreases servo travel on the brake side only. My CRX is the first radio I've had with ATL and it's a feature I've really grown to like. I usually use it to make small adjustment to braking while I'm in for a pit stop.
Old 08-05-2005, 03:13 PM
Mad Wax
Mad Wax's Avatar
Default RE: ATL ?
Is channel EPA the same? Just set EPA brake to maximum level of travel- say to just where the servo starts to strain a bit (and same for throttle so servo doesn't tug on carb horn trying to go past it's limits) My steering servos are around 65% (full lock) 91% for throttle, 70% for brake, 65% for 3ch (second servo, mixing)
Might move the steering placement on notch towards the hub (more torque) then increase EPA for steering.
Old 08-05-2005, 03:34 PM
P2gee
Default RE: ATL ?
EPA has priority over ATL. ATL will only adjust the travel within the limits you have set with your EPA adjustment.
Old 08-05-2005, 03:49 PM
Mad Wax
Mad Wax's Avatar
Default RE: ATL ?
From the manual
DEFINITIONS:
• ATL, electronic: (Adjustable throttle limiter) Adjusts total travel available to the
braking side of the throttle servo, similar to adjusting EPA, but allows adjustment
“on the fly” when ATL is assigned to a dial. When brake mixing is used in the
unmixed mode, this adjusts the rear brake servo without changing amount of braking
to front brake servo.
• ATL, mechanical: Decreases the physical distance the brake trigger can move.
See p. 51.
Since T/B servo will be set "on the bench" it's unlikely you need on the fly dial constant adjustments, or perhaps if brake is insufficient on a new model- hold up rear wheels, go into EP mode and increase a brake servo movement a couple of notches, then try braking again (not you need on the fly adjustments like steering centre points if it drifts to the left/right) I've disabled the two rotary dials on the index finger.
