Charger Needs
Charger Needs
Hey guys i posted this elsewhere in this forum but thought this place would be more logical..Im new to this charging and discharging business
I was wondering which charger is cheap and good enough to charge tx n rx batteries for off-road nitro use.. Also if i get a charger.. do i need to get a power supply..? Thanks
RE: Charger Needs
ORIGINAL: Zukre Iskotehx
For decent charger that is AC/DC, will charge small cells (like the 2/3A in hump) and AA's, and will charge 8 cells (Tx) i would suggest [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCLD5&P=ML]duratrax digital peak[/link]. It'll get the job done. One warning though, it doesn't want to charge my TX while hooked up to the car battery. I don't think there's enough voltage to charge 8 cells. Pull em out and charge them in a 4 cell holder.
RE: Charger Needs
You will benefit from a charger that can discharge as well. It should also automatically detect when the batteries are fully charged.
Furthermore you need to be aware of the voltage if you order from abroad. In US they have 110V whereas we have 230V in some parts of Europe. The frequency of the AC should also match.
RE: Charger Needs
ORIGINAL: Engrose
