RC Car Radio Equipment Discuss specific topics related to RC car radios. For general or non rc car specific radio topics please see our regular radio discussion forum.
jr xs3 radio problem
Old 03-18-2006, 05:00 AM
My Feedback: (-1)
vic2367's Avatar
Default jr xs3 radio problem
hi all...was wondering if anyone had this problem before,,,whenever i give my radio throttle my rc goes in reverse,,,and when i give it reverse on the throttle it goes forword...any suggestions on how to fix this,,,im kinda new to all this ,,,on my radio i have it on normal where it says normal / reverse screen ...i played with those settings but it still does the same thing...anything? thanks all,,,vic
Old 03-18-2006, 12:07 PM
Default RE: jr xs3 radio problem
Either one of normal or reverse setting on the throttle channel should correct the problem. If you are positive you have tried both and none worked, then I would suspect something is wrong with your TX.
Old 03-18-2006, 02:00 PM
My Feedback: (-1)
vic2367's Avatar
yeah i think its my my tx ... i tried adjusting the reverse/throttle adjustment screen ,,,reversing the servo ,,,nothing,,
Old 03-18-2006, 02:02 PM
My Feedback: (-1)
vic2367's Avatar
oh,,by the way,,mr reciever is the jr 310...
Old 03-20-2006, 08:59 AM
gerwen's Avatar
Make sure you're reversing the correct function. You could be adjusting the steering or 3rd channel.
From the manual, pg28
1.Turn the transmitter power switch on.
2.Press the Scroll key to access Function Mode.
3.Press the Scroll key until “REV.NORM” appears in small
letters to the right of the screen.
4.Press the Channel key to select the channel to be
changed (ST = Steering, TH = Throttle, AUX = Auxiliary
Channel 3).
5.Press the Increase or Decrease keys to move the cursor
to the desired direction.
6.To exit the Function mode, either turn off the transmitter
power switch or press the Scroll and Channel keys at the
same time.
Old 03-20-2006, 11:33 PM
My Feedback: (-1)
vic2367's Avatar
hey gerwin ,,,ur tip helped,,,corrected my problem...thanks alot man,,,,vic ,,
Old 03-21-2006, 08:35 AM
gerwen's Avatar
No problem. Until you get used to all the functions on the radio, it's easy to adjust the wrong thing.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
