Nomadio React 2.4GHz Radio
#152
I told you this radio is sweet and you don't need and hand book to run it . Just go to your desktop and plug in your radio and all updates come right threw there sweet
Check out my back light. Just a cheap little book light works great. You can get the RX at tower for $109 and then use the coupon and get it for $89 with shipping.
#154
CO
the " NOMADIO SENSOR EXTRA V2 TRANSCEIVER KIT " Tower Hobbies stock # LKLKU8 is $109.99 , is this what you are saying you can buy for $89.00? HOW?
#155
There is a thread on here that is just for tower coupons. one code is 010f3 and there is 010bm but that one is for 30 bucks off $198 dollars. But check the thread and you can find them
#159
My Feedback: (-1)
TX
ALl right, so I did donwload the Beta version of the software to try and bind my react with my DSM receiver. However, under advanced setting of one of my model i DO NOT see the "Transceiver" option like the software release manul stated !!!
Am I crazy or something ?
#162
http://nomadio.net/software/react3/beta
In RC Desktop Pick the model you want then under advanced you will see Transceiver it is set to NORMAL by default drop down menu set to DSSS
#163
My Feedback: (-1)
TX
All right, DSM works great, all 5 of my trucks now programmed into the React and I LOVE IT...
I do have a question, have any of you mounted the speed sensor in a Revo yet and if so, where and if you could provide pics it would be great ...
#164
Hear you go.
http://support.nomadio.net/viewtopic...highlight=revo
The intsall for a Revo without a center diff is the same you just have to move the sensor forward a little. This install is on a 2.5 chassis but, the 3.3 should be similar
Mike
Mike
#165
TX
ORIGINAL: SavageRevo
#166
My Feedback: (-1)
TX
ORIGINAL: P2gee
I hope you understand that the Nomadio speed sensor will not work with Spek DSM receivers. You will have to use the Nomadio receiver in FHDSS mode.
#167
Hey I was wondering if you can use the radio with any reciver are does it have to be 2.4GHz or higher? What I mean is can you use it with your stock recivers?
#168
MI
ORIGINAL: giddyuperic
Thanks, James
#171
Thanks. Now I was wondering if you can buy the female part of the charging cords, you know the one that you would hook the battery up to? Or has someone made there own hook up and could tell me what they used? Any help would be great as the USB charging cord just doesent do a very good job. thank you very much. Eric P.S. Can you tell me what is draining the battery when it's just siting on the shelf??? It's really starting to bug me and with the USB charger it takes I have had it on there for 23 hours and it still say's not charged?????
#172
UT
yeah, yeah, me too! I would like some of the connecters that are on the stock battery. That way I can build an extra pack with batts I allready have. Will these be available? Or maybe a link where they already are? thanks.... post u later
