RC Car Radio Equipment Discuss specific topics related to RC car radios. For general or non rc car specific radio topics please see our regular radio discussion forum.
how set the fail safe on DX3.0
Old 01-28-2008, 10:47 AM
JB COMP
JB COMP's Avatar
Default how set the fail safe on DX3.0
How do you set the fail safe on the DX3.0 after the binding has been done?
Old 01-28-2008, 01:03 PM
RCUSEE
Default RE: how set the fail safe on DX3.0
i think you ll have to rebind it :/
Old 01-28-2008, 04:16 PM
fastxr
fastxr's Avatar
The intructions for setting the failsafe on the dx3 or the dx2 are as follows:
1. hold down the bind button on the reciever and turn on the power to the reciever, hold button till it starts blinking rapidly.
2. Hold throttle trigger on transmitter in the failsafe position you would like it to be set to (usually full brake), then hold down the bind button as well and turn on the transmitter while holding the thottle and the bind button and the lite on the Tx bind should start blinking as well.
Thats it, test the failsafe by turning of the transmitter.
Old 01-28-2008, 05:31 PM
j_blaze
j_blaze's Avatar
make sure servos are norm/reverse before you do or else it will wot when it thinks its at full brake. been there, done that.
Old 01-28-2008, 06:02 PM
RCUSEE
^^yea that just gave me a déj*-vu
but he asked if its possible to adjust the failsafeoption after binding.
Old 01-28-2008, 09:20 PM
JB COMP
JB COMP's Avatar
right now, (I did what fastxr said) when I first got it, but when I turn on the RX the throttle opens about half way, on both my cars that have spektrum.
so when I turn on my RX and where the servos go thats their failsafe mode or spot? (or what ever you want to call it)
Old 01-28-2008, 11:24 PM
fastxr
fastxr's Avatar
If you turn on the reciever without the transmitter turned on then yes the throttle/brake servo should go to failsafe mode. If its not set right, I would just try redoing the process, you can bind over and over again without messing anything up. Perhaps as J_blaze stated that the servos were reversed the first time you went through the binding process. Good Luck
Old 01-29-2008, 09:43 AM
JB COMP
JB COMP's Avatar
Ok, I'll try binding it again.
I guess its a good thing I haven't need the failsafe mode yet
Old 01-29-2008, 10:55 AM
383ysi
went through this the other day, bind the rx, then the tx while holding the steering any way and the brake, after that, go through the bind process the regular way
