RC Car Radio Equipment Discuss specific topics related to RC car radios. For general or non rc car specific radio topics please see our regular radio discussion forum.
Tamiya 6 channel Transmitter
Old 05-28-2008, 10:02 PM
astroboycp
astroboycp's Avatar
Default Tamiya 6 channel Transmitter
Anyone knows about Tamiya's 6 channel transmitter?
Old 05-31-2008, 10:50 AM
dacaur
dacaur's Avatar
Default RE: Tamiya 6 channel Transmitter
i read about it in an RC mag, but haven't found any other info on it... its not even on tamiya's site.... chances are it wont be cheap enough to make it worthwhile.... I would say just get a spektrum DX6 if you need a 6 ch radio... its guaranteed to have more features than the tamiya, probably wont cost much more, and is better for scale looks because the antenna doesn't need to extend outside the body at all.
Old 06-04-2008, 09:10 PM
astroboycp
astroboycp's Avatar
I am not too sure if the DX6 will work with 1/14 Truck MFU system as it is digital trim not analog. That is why I was looking at their 6 channel analog transmitter.
Old 06-04-2008, 09:11 PM
astroboycp
astroboycp's Avatar
It was great to hear some response as I thought I was the only one who heard about it.
Old 06-04-2008, 11:07 PM
dacaur
dacaur's Avatar
Well, im not sure if you are aware, but hitec makes its laser 6, 6 channel TX in surface frequency... (75Mhz) .... You can pick one up new for $80 or used for around half that...
http://www.servocity.com/html/laser_...d_systems.html
Old 06-05-2008, 01:25 AM
astroboycp
astroboycp's Avatar
I've been searching for details on the Tamiya 6 channel but turn up nothing.
Old 06-25-2008, 09:02 PM
astroboycp
astroboycp's Avatar
It might seem like the TX is not a new item?
Old 07-17-2008, 10:51 AM
Mouton
Mouton's Avatar
No, the Tamiya 6 channel transmitter is actually quite old.
The Tamiya MFUs work best with Futaba 4VWD. That is the radio Tamiya include with their full operation kits (for the semis). The Futaba 4VWD has been replaced by the 4GWD, which has digital trim levers, which does not work with some MFUs. The Futaba 4Yf is another cheap option that also works with the MFUs. The older Futaba FF6 is a 6 channel Futaba with analogue trim levers.
Actually any stick type radio with 4 channels (or more) that has analogue trim levers will work with a Tamiya MFU. Keep in mind that you will need to get a transmitter that is legal for ground use in your country.
I use a 25+ year old JR Pulse radio with my MFU and it works perfectly.
