NEED help with RADIO
hi there everyone... just a quick note to ask for help.... I have a sanwa geminii 2 and a spektrum DX6... What i am after is can i turn the DX6 to a surface radio if not what other radio's can i use instead of the DX6 thay have to be stick only.....I am looking to get away from crystals .....
RE: NEED help with RADIO
The DX6 is 2.4Ghz, which is approved for surface use as well as air. The only problem you will have is that there is no return spring on the throttle stick....
