RC Car Radio Equipment Discuss specific topics related to RC car radios. For general or non rc car specific radio topics please see our regular radio discussion forum.
KO Propo EX-5 UR
Old 03-08-2011, 05:44 AM
Wayne Drayton
Default RE: KO Propo EX-5 UR
Hello again,
I've made up a croc clip charging lead and I can now charge the TX batteries quite happily, they are 3600mah so hopefully this 2.4 system wont drain them too quickly?
However, I seem to have developed a problem with my steering servo its rather twitchy when I turn the steer wheel, especially when its at the end point. When I release the steer wheel back to neutral it calms down......if I don't turn the steer wheel there is no movement/ twitching so maybe it's not interfererence?? It doesn't do it when I use the old AM radio setup so hopefully the servo isn't busted so I'm unsure what the problem is........the throttle servo had a similar issue but by adjusting the end point/ trims it seems to have stopped but it was with more luck than judgement...
any clues/ opinions always appreciated
cheers
Old 03-08-2011, 06:07 AM
markymark
ok wayne check your end point adjustments on the transmitter this may help stop the twitches by limiting the movement but i find i get slight tiches when my controller within a meter of the car,but it settles after a min or 2,i had a funny 5 mins with my controller last weekend where it delayed the movement but once it passed it was ok,the outher thing i noticed is they like lots rx power,so keep them well charged and run 6 volts
Old 03-08-2011, 08:01 AM
Wayne Drayton
cheers Mark,
I will try at a greater distance as I was testing within half a meter!!
cheers
Old 03-23-2011, 04:23 AM
Wayne Drayton
Back on this!
I actually tested running the truggy today and the steering/ throttle brake was fine so all seems to be ok. I guess sometimes you can pay too much 'close up' attention to these models.....in this instance the servos making strange humming noises etc......but if turns, screams off and breaks whats the problem??!!
cheers
Old 03-23-2011, 06:05 AM
markymark
well i agree that there servo noise,but no problems when on the track or park,so yes it works but the servo noise does take a bit of getting used to
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
