How fast does it go?
Wanted to check how fast my unknown little .21 Go engine could be.
I don't own a fancy smancy skyrc GPS thingamabob, so decided my trusty OLD Garmin would need to do.
Tried tuning my HSN again for a bit more top speed, but that is all she got. LOL!
My experience with those GPSes is that they need quite a while in a straight line to display the speed properly. Like ten seconds at constant speed at least, probably longer.
And since that kind of car can do easily 20+ m/sec, that would mean that you really need to run it 200+ metres in a straight line at constant speed.
Probably, if you find a suitable place where you can chase it in a car and run it all out for half a kilometre, you will probably get better numbers. The averages are simple calculated values (distances divided by times) and those are pretty much correct all the time. But max speed is a measured speed with a damping, and it needs time for the readout to stabilize.
At least, my own GPS (TomTom) always lags quite a bit behind before the speed readout stabilizes.
