X-Maxx 8s EzRun 4985 SL 1650KV Upgrade
Hello~~
I upgraded to XMaxx 8S EzRun 4985 SL 1650KV. The gear ratio is 18/50 M1. First off, it's very fast. ^^; I get a lot of heat. ;; I need to install a cooling fan. Jumping and high-speed driving seem to be the best. The motor mount used JH Racing CNC aluminum. Like the genuine parts, the gear ratio can be adjusted with dowel pins. Of course, the existing genuine gear M1 is used and the gear cover is also assembled. And after replacing the big servo, the servo force was too strong, so the tie rod (plastic) connecting the servo horn was bent, so I replaced it with NEW ENRON aluminum. The steering ability is definitely working. Satisfied!!! Traxxas X-Maxx 8s ESC : Hobbywing EzRun MAX6 Motor : Hobbywing EzRun 4985 SL 1650KV brushless motor Servo : POWER HD WH 65KG Digital Servo Metal Gear Tire : Pro-Line Racing Badlands MX43 Battery : DXF 8400mah 120c 4s X 2 Body : Pro-Line Racing Pre-Cut Brute Bash Armor Body (White) Gear : 18/50 Spring : Pro-Line Racing Dual Rate Spring Assortment Motor mount : JH Racing CNC aluminum alloy motor fixing bracket Tie Rod : NEW ENRON Aluminum 46MM Servo Steering Linkage Tie Rod - PART - RPM 81732 Oversized Rear Axle Carriers |
