Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Classic Cars & Trucks
Reload this Page >
Lee's vintage TA-03R S TRF build thread
RC Classic Cars & Trucks Have a classic that is at least 15 years or older? Discuss it here!
Old 04-17-2007, 05:39 PM
lee172
lee172's Avatar
Default RE: Lee's vintage TA-03 R S TRF build thread
ive just bought one! the 5700kv was for the M-03R, but it could jump to my new F103 RS project..
rear ball diff and counter shaft..
ID:	666771   Click image for larger version
Old 04-17-2007, 06:20 PM
lee172
lee172's Avatar
made a classic mistake.. put the wrong gearbox joint (long instead of short) in the rear.. an easy fix though
i also learned something new today, in the Tamiya build manuals, the breakdown of the parts (on the left of the page) are to scale! and no, i'm not joking [&:][&:]
its about the 3rd time ive said it, but thats it for today.. [:'(]
ID:	666799   Click image for larger version
Old 04-17-2007, 06:25 PM
Lunchboxer
Lunchboxer's Avatar
Wa, you didn't know?! Also the distance, etc. are all scale too.. (so when you build turnbuckles, set pinion, etc. you can just put the parts to the manual to get the required distance..)
ORIGINAL: lee172
Old 04-17-2007, 06:35 PM
Raguvian
Lee.[:@][&:]
Old 04-17-2007, 09:41 PM
takzi
Beautiful! Lee!
This chassis was so great in terms of the look, so i got one for myself too. to make it a shelf queen, i have throw in the unique 911 GT1 body which was deisgned specially for RS chassis....:-)
P.S. You gotta have one of those red option belt to make the car even better!!
Cheers
takzi
Old 04-18-2007, 08:24 AM
  #31
lee172
lee172's Avatar
thats a nice ride!
battery tray is attached and the bling servo mechanism is done.. all bolted together..
ID:	667091   Click image for larger version
ID:	667092   Click image for larger version
Old 04-18-2007, 08:34 AM
  #32
Lunchboxer
Lunchboxer's Avatar
SICK!!! I like it!!
ORIGINAL: takzi
Old 04-18-2007, 08:36 AM
  #33
lee172
lee172's Avatar
main chassis nearly complete.. very odd servo saver.. and servo fully built..
ive also stripped the head on a countersunk screw.. which i need to access as the servo need to be altered slightly.. [:@]
ID:	667105   Click image for larger version
ID:	667106   Click image for larger version
Old 04-18-2007, 08:38 AM
  #34
ScsFactor
Awesome!
ORIGINAL: takzi
Old 04-18-2007, 08:50 AM
  #35
lee172
lee172's Avatar
tyres being built up.. they look like scale race tyres, as they have some white print on the main carcass.. cool!
Old 04-18-2007, 08:55 AM
  #36
Lunchboxer
Lunchboxer's Avatar
I have a couple of those, they are actually pretty good!!
ORIGINAL: lee172
Old 04-18-2007, 09:35 AM
  #37
lee172
lee172's Avatar
just had a major drilling operation to try and save the servo mount.. i failed.. looks like i need to find a new one.. [:@]
it i see a titanium screw set i might bag that as well, these ones round off much too easy..
Old 04-18-2007, 09:44 AM
  #38
Lunchboxer
Lunchboxer's Avatar
You can't use an extracting bit to get it out?
Old 04-18-2007, 09:49 AM
  #39
lee172
lee172's Avatar
i'd never heard of one! doubtful that we have one anyway.. item 53308, Tamiya servo stay.. discontinued.. [:@]
looks like some silver ones then..
Old 04-18-2007, 09:59 AM
  #40
Lunchboxer
Lunchboxer's Avatar
They should have it in some hardware store..
Basically, you use a drill and drill a small hole in the broken screw..
Then you use this "extracting bit" that has reverse thread and try to screw into the broken screw.. and it will lock on to it and when you keep on turning it counterclockwise, you will get the screw out...
Good luck!!
Old 04-18-2007, 11:12 AM
  #41
takzi
ORIGINAL: Lunchboxer
Good luck!!
That was what i heard too....bsaically u do need some very steady hand when you perform such drilling in that tiny place..
good luck~~~ this purple servo stay is an important part to complete this great chassis~
Old 04-18-2007, 11:29 AM
  #42
Lunchboxer
Lunchboxer's Avatar
Yes, it would help to have a drill press and a vice grip....
ORIGINAL: takzi
Old 04-18-2007, 02:08 PM
  #43
Yub, yub, cmdr!
Yub, yub, cmdr!'s Avatar
Haha LB a drill press!
Old 04-18-2007, 02:18 PM
  #44
Lunchboxer
Lunchboxer's Avatar
You don't need an industrial strength one.. it shouldn't cost too much, if you got the space for it..
I'd get a end mill.....
Old 04-18-2007, 02:42 PM
  #45
lee172
lee172's Avatar
no pressure then!
Old 04-18-2007, 02:45 PM
  #46
Lunchboxer
Lunchboxer's Avatar
Yeah, be careful.. last time I tried to drill a broken ball connector out of my TXT aluminum axle guard, I broke the drill bit and it slipped and I put a broken bit into my finger..
Not a pretty picture.. [&:]
Old 04-18-2007, 03:28 PM
  #47
Lunchboxer
Lunchboxer's Avatar
If you don't mind a slight damage to the servo mount (it won't affect the function or anything), you ca take a Dremel tool and use the smallest cutting disc.. and cut a slot on the broken bit.. (and you might cut in to the aluminum somehow, just slightly..) and then you can use a flathead screwdriver and drive out the broken bit..
Old 04-18-2007, 03:35 PM
  #48
lee172
lee172's Avatar
worse case scenario = i wreck the mount, in which case i'll get the silver aluminium ones.. it wont look too out of place as there's plenty of silver bling on the car also..
so for the time being, the build has ground to a halt.. [:@]
Old 04-18-2007, 03:38 PM
  #49
Lunchboxer
Lunchboxer's Avatar
See my post above, you will get it out if you don't mind a small slot on your servo mount.. (and since cutting disc is round, hence, disc, LOL! it will be pretty light cut on the mount, actually... so..) No need for that to stop your build..
Old 04-18-2007, 03:52 PM
  #50
lee172
lee172's Avatar
i dont have a dremel, and the only small tipped screwdrivers we have, also have small handles, so not enough grip available..
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
