need info on ta-02
got a used one coming.
need any infor you got on them. weak points? Good mods to do? Upgrades you reccomend? i will either A: turn it into a scale trail truck. lock diffs, 1.9 crawler tires ect B: run it on my buddies track with a basic brushed system. a few jumps, nothing brutal. |
RE: need info on ta-02
1 Attachment(s)
which cars did the ta02 come under, if i recall isn't the s-10 one of them? if so it's a little weak for modding, too much plastic!
ta02's are tougher then you'd think. they are based on the df01/ta01. i have a df01 4wd buggy with a brushless system, the only upgrades i needed to do was an alloy prop shaft and cvd's.
just make sure the parts you buy say they'll work on a ta02 as they aren't as long as the df01/ta01. |
