Giant Combat Gremlin or Predator?
Anyone blown up a Combat Gremlin or Tufflight Predator?
I was thinking about doing a 1.20 sized just for kicks... or am I just insane? Anyone got a 3-view or drawing with some measurements of the original? Post pics of anthing you got... CrazyHerb |
RE: Giant Combat Gremlin or Predator?
1 Attachment(s)
Yes Herb,
your insane, or just plane crazy Sounds like fun Gremlin span 48" root chord 14" tip chord 10.5" airfoil thickness at root 1 7/8" 1 5/8 at tip Elevons 1.5" cg 1 5/8"from LE does that about cover it hope this helped. BTW cool stuff on your website Hey does anyone know where I left my gremlin??? |
late reply but here goes - I've nearly finished building one of these . . .
The Super Gremlin - made for Ryobi power [link=http://www.gotgasradiocontrol.com/gremlin.html]Super Gremlin[/link] |
CrazyHerb,
You can get the plans for the original Gremlin from the RCM plans service. [link]http://www.rcmmagazine.com/store/store-plans-list-1.html?sid=0001on7CV01n5OsZtM4x3X0[/link] It is plan #1134 @ $10. You can take the plans to a print shop and have them blown up to whatever size you need. I have built a number of Gremlins and loved every one. The original plans were for a .25 size engine. I did put a run out .40 on one once. Did fine. What do you intend to use for a fuselage? The original was a plastic down spout and I don't think that it would support a big 1.20. I believe that I would consider using a built up balsa/ply fuselage and cover it in fiberglass. The only criticism that I have of the Gremlin is the elevon servos are mounted in the fuselage and attached to the elevons on the wing. Any time that you catch a wing tip on a landing or cause the wing to separate from the fuselage it is guaranteed that you will jerk the gears out of the servo, break the control horns and/or bust the cases. If I build any more I will mount the servos in the wing. Keep us posted on how goes the build. |
| All times are GMT -8. The time now is 07:24 AM. |
