Need opinions for new combat plane
I have been through a few combat designs but I have tended to go for cool vs. combat abilty. Therefore the guys at out field have had a hayday with me. Well enough is enough. I need a new weapon and wanted to get some opinions. Right now I am using a Grim's Sickle with a mousse canned Magnum 25 on it. It wont out-turn anything! I have the resources to build these... Please give me your pick.
SPAD Flat Bat (got a bat lying around) Any SPAD 25 size plane Battle Floyd I have a mini flight pack (270 battery, HS-81 MG's, Magnum 25 w/ mousse can, spinning MA 9X5 at 15,500 rpm) If you have had good luck with any particular design, please let me know. We aren't real formal at my field, it's a free for all with 25's to 40's all competing together for fun. I look forward to your responses |
I have just three letters for you: PBF
You might want to check out the HOR by the SPAD folks. They use .15's on it, but I fly them with .25's and even a .46. They are a snap to build too. Instead of the coro wing, I use a 64" foam wing, but the coro wing should be fine. just that the 64" has more cutting area. Also the foam wing will be stronger.
I recommend the SPAD Debut. I know, they call it an Introductory combat plane, but I flew one for several events and won or placed in all but one. I am now flying HOR's, because the fuse is sturdier, but with a Debut wing they fly identically. It does not have the top end of a Bandit or Avenger (aerodynamics), but it turns with anything out there. :cool:
Good flying to you. |
The SPAD HOR is the easiest quickest building plane you can get
Sorry my pick for you is not on your list, but I would suggest the SPAD H.O.R. - Hell On Rails. If you can swing getting the foam wings you will be really happy! You can get some pretty cheaply from Mike Fredricks of Hat Trick Enterprises: www.hattrickrc.com
The H.O.R. is really strong and easy to build - it flys better than anything on your list. Anything you can do to reduce the wing loading just makes the H.O.R. even better. |
mc130p_fe,
I wouldn't give up on the Grim Sickle, stretch the wing span to 48" or 60". I have had good luck with them, even flying them at 72" and 84" wingspans in open C. |
You want something that will fly circles around ANYTHING? Let me know. :eek:
[email protected] |
Yeah, Jimbo's design flys circles around everyone, because everyone is busy turning inside him to make a cut.
Just kidding Jimbo, it was just too easy of an opening. |
I was initally exposed to Combat when I was on business in Cinncy. There was a guy there that was flying the SPAD, Flat Bat Combat with a 25 on it. I was so impressed with it, that I checked it out on www.spadtothebone.com. I've built a few for my son and I to play with. I've since built 18 ARFs for the Flat Bat Combat because I was so impressed on how they fly, and I am selling them locally to stimulate interest in COMBAT. Needless to say, I would strongly recommend the Flat Bat Combat.
Kevin :D |
Do you build the flatbat to the plans on the SPAD site or make modifications? How quick is it compared to the SPAD HOR (I'm leaning that way, but I do have a flat bat here). What engine do you use?
The Flat Bat was designed for B class competition and .25 sized engines....and the HOR was designed for SSC class combat and .15 sized engines. There is absolutely nothing stopping you from using the Flat Bat wing and tail (larger) and strapping them to a HOR fuselage for an awesome airplane!!! The Bats are awesome, and your equipment is safer inside the fuselage and away from exhaust goo...but man...the HOR's sure are easy to build:)
Sorry - but I have no comparison to the SPAD HOR. As far as modifications, I install a pc. of tri-stk in the center of the V-Tail and sand it to match the contour of the bat handle. I just find it easier to install. I also enlarge the control surfaces slightly (only because I'm a Fun Fly kind of person). I run a Webra 32 on mine. It comes in at just under 3-1/2 lbs with 2-std & 1 mini servo.
Hope that this helps! Kevin :D |
I'll tell you for sure what NOT to get: Battle Floyd. Back in the days of balsa in Open combat, these made it rain balsa. Then came the SPADs, and it began to snow pink foam. With the invention of water-based polyurethane came the era of carbon-reinforced-foam-covered-with-ripstop-nylon, and coroplast meteor showers.
Bang for the buck, SPADs are tough to beat, though. They hold up in midairs against their own kind and lesser planes, and are cheap and easy to build. It takes several hours of painstaking labor to coat a foam wing with ripstop nylon, and even these don't last forever. |
I haven't built a B class version yet, but my A class design is basically a heavily modified Battle Floyd. They fly great, and with a few changes are actually very durable for their size. I do think a Floyd in B class is dead meat if built stock. (have a picture around here somewhere to prove it)
I'd say the spads are good options. There seem be a few guys flying HORs in B class with success. The key is weight and wing area. Whatever you build, the lighter the wing loading, the better your turns and overall performace will be. So keep it light and put on the biggest wing you can manage. |
http://www.wheek.org/airplanes/studley7.jpg
The debris field in the middle of the picture is a stock Battle Floyd coming apart after my Skull Bandit (leaving on the right) flew through it. My Bandit had a small dent on the wing LE. The Floyd is in worse shape than the picture might indicate. |
Thanks for all the advice. I built a H.O.R. I am having a hard time telling my wife what the name of the design is. "Honey I built a ...." well, you get the idea. Hehe. I'll test it tomorrow.
Thanks fellas! Dave |
Thanks for all the advice. I built a H.O.R. I am having a hard time telling my wife what the name of the design is. "Honey I built a ...." well, you get the idea. Hehe. I'll test it tomorrow. What is wrong with this? Subject: Here is a picture of my new HOR <<wife holding "a plane">> Thats a good way to get slapped if you cant explain that one fast enough! :D |
Dave,
I have been using the flat bats for combat for about 8 months and they will hang with the best of them! I have one that I built from the SPAD website and I am sure that you would be super happy with the way it flies. It will turn with the best of them and it has the speed that it needs to chase the .40 size birds. I am using the same radio gear that you are using and the same engine. The only difference is that I use a 9x4 master airscrew for the prop. If you check the SPAD combat results for the month of March, you will see that a 15 year old came in third using a flat bat. If you would like pics, I would be happy to send you some. Bob |
Flat Bat
Dave if you will look at the March KS combat results you will see that a 31 year old won the meet with a flatbat. If you go to the RCCA Page you will see that fella just set an RCCA record round of ten cuts with it. Do I believe in the Flatbat You bet!!!! IMHO it's the best thing around. The specs on mine are a 64" foam wing covered in nylon and a 21" bat with conventional tail surfaces no v-tail. The Paris TX meet will be on my mind for some time to come man what a great time.
Don "Tenman" Howard |
Hey Don,
Congrats! Mitch told me of your outstanding success in Paris. I wish I could have been there. I hope to see you at the Wichita April meet where you will not be as lucky, this time. SwampBoy |
Swampboy hows your dad doing? Sure hope he is doing better sounds like he was pretty sick. I've been off work for 3 days myself got some bad stuff going around. I don't think I'll be in Ks next month. I'll see you in Junction City though. The following weekend is the next NTRR and I'll be going to it. See Ya in JunK city.
New Combat Plane
1 Attachment(s)
If I had a choice I would fly a Fight Master 30 combat Plane. Of course I am the designer of the plane, so I might be a little bias. It is by far the fastest and quickest
turning airplane I have ever seen or flown. I used to Fly my Fight Master 60 in our clubs open combat events but my Fight Master 30 powered by a OS Max .28 engine is just awesome. I in fact won our AMA sanctioned event today because of it's great speed and turning ability. It flies well over a hundred miles per hours while pulling a 30 foot long 2 inch wide crepe paper streamer and still turns on a dime. John Boren |
I didn't see any Chicago events on the contest calander on the RCCA site. Did you post it? I would have come down if I would have known!
Listed In the AMA Magazine
I don't believe any one in my club is currently a member of the RCCA, so I don't believe we could post the event even though we use their rules except engine size. Every year we have a one day open combat event with the only restriction being the maximum engine displacement of .75. We had one .60 powered plane, my .28 powered Fight Master 30 and the rest were powered from .40 .50 size engines. Believe it or not my .28 powered plane was by far the fastest plane out there. It was even faster then the second faster plane out there, my Quickee 500 pylon racer. We had about $250.00 worth of prizes. Years ago we used to give out $200.00 cash for first place plus prizes but not enough people have showing up in past years, so we had to cut back on the prizes.
John Boren |
| All times are GMT -8. The time now is 07:34 AM. |
