RCU Forums
-   RC Combat (https://www.rcuniverse.com/forum/rc-combat-94/)
-   -   bombing systeem (https://www.rcuniverse.com/forum/rc-combat-94/629736-bombing-systeem.html)
DutcheR 03-17-2003 07:02 AM
bombing systeem
doesa any of you have a bomber who really can drop bombs ? post pictures please
Matt Kirsch 03-17-2003 04:25 PM
bombing systeem
R/C combat has nothing to do with dropping bombs or shooting at each other. We attach crepe paper streamers to the tails of our airplanes and chase each other around, trying to cut the streamers with our propellers.
There are two main reasons to add bomb bays or bomb drops to an airplane: Scale detail, or fun (e.g. dropping candy or plastic figures with parachutes on them).
DutcheR 03-17-2003 04:27 PM
bombing systeem
i was more thinking on eggs :p but there are enough planes who got it or an camera or something!
CrazyHerb-RCU-delete 03-17-2003 05:48 PM
Try the Fun-Fly Forum
Try asking the same question in the the fun-fly forum.
There is a Fun-fly competition called the "Egg-Drop"...ask how they do it....
I think usually it's a plastic cup fastened to the top of the plane...to drop...just do a roll. And LOOK OUT! SPLAT!!!
There also used to be a company called Vortac that made a servo operated bomb drop mechanism.....don't know if they are still around or not.
High Flights!
CrazyHerb
Matt Kirsch 03-18-2003 04:12 PM
bombing systeem
You also don't have to be a rocket scientist to figure out how to build a box that can be opened with a servo.
coro kid 03-22-2003 04:36 AM
bombing systeem
DutcheR
go to Spad site and search for bomb drop by MR Clean ,he also designed a bomb with flour in it made from foam cups.If i can find link I`ll post it.Who said combat plane don`t drop bombs?:D When I get my spad version done I`ll post it.Fly alittle combat,fly alittle fun fly,who cares its all fun.Why not add a bombing event to combat for fun.
CORO KID
:D
rrh 03-22-2003 06:09 PM
bombing systeem
Here's my simple bomb bay, no rocket science required. Works great!
http://j***amily.org/rc_albums/combat/akm.sized.jpg
rrh
coro kid 03-23-2003 12:14 AM
bombing systeem
I like it!
Did you make it to rubber band on any plane?
CORO KID
rrh 03-23-2003 01:45 AM
bombing systeem
Yep, with those dowells I just rubber band it in place. I have a giant Deb tail dragger and put it on the CG. I made some tall LG for added clearance. Whiffle golf balls make good bombs, parachute guys drift a long ways from a high drop if you don't judge the wind right.
rrh
EvilMike 03-23-2003 03:13 PM
bombing systeem
You can make a very simple system by mounting a servo next to the fuselage side, and having a pushrod stick out through a tube in the side of the fuse. Make its lenght so that when you flip the switch the pushrod retracts fully into the fuselage. You can then put a rubber band on the pushrod where it exits the fuse, and attach the other end to a wing hold down dowel. When the pushrod retracts, the rubber band will come loose, dropping any load you mounted underneath it.
n553302 04-05-2003 06:55 AM
bombing systeem
DutcheR, If you go to my picture gallery you will find a camera and a bomb drop to give you some ideas.
chuckster 04-06-2003 02:59 AM
bombing systeem
i took a pvc box, removed the radius. hinged the coro, i took out 2 flutes, now the coro when it bends, has a radius of its own. and secured them with rivets so there is nothing to get snagged on.. once the elastic is released, the coro returns to it's original form and well, the doors open all the way.. i omitted the end corocap to reveal the inside of my bay. a pic is worth a thousand words so here they are.
this design could be mounted on any style of plane.. and it's made with scraps i had laying around.
http://www3.sympatico.ca/the_nest/bomb1.jpg
http://www3.sympatico.ca/the_nest/bomb2.jpg
http://www3.sympatico.ca/the_nest/bomb3.jpg
http://www3.sympatico.ca/the_nest/bomb4.jpg
