RCU Forums
-   RC Combat (https://www.rcuniverse.com/forum/rc-combat-94/)
-   -   XR Combat wing assembly (https://www.rcuniverse.com/forum/rc-combat-94/8149172-xr-combat-wing-assembly.html)
mofosheee 11-15-2008 03:49 AM
1 Attachment(s)
Dear Brothers:
I recently purchased an EEP foam 48" combat wing from combatwings.com. My first glider
I am finding it difficult to insert the carbon fiber rod that connects the wing halves.
It seems that the holes are not drilled deep enough to accept the entire rod. If I try to force the issue the rod goes in at an angle.
Did the mfg not drill the holes deep enough or am I being dumb.
Any tips appreciated
Thanks all
qwertypemdas 11-17-2008 11:05 PM
RE: XR Combat wing assembly
Must have got a lemon?
combatpigg 11-19-2008 01:59 AM
mfs, if you can insert the spar 90% of the way, that should be good enough.
You could get an exact fitting length of brass tube, chuck it into a drill motor, then ream the inside edge of the tube with an Xacto blade until it's sharp. Now you've got a tool that can deepen the holes in the wing panels if you're careful.
mofosheee 11-19-2008 11:56 AM
The thin wall brass tube worked excellent..........
Thank you
