brushless pan car
LA
brushless pan car
ok here i go i was going to set up my rj speed pro stock car with a mamba max 5700 on a 3cell lipo but i dont think it can handle that kind of power!!! and i dont want to get a gms car becuse i mostly race in parking lots and i dont think i would be able to maintain good enough traction with such a narow wheel base to go as fast as i want so would ae rc12l4 pan car be a alternative with out loosing to much speed becuase they both are direct drive cars! so my queston is if a gms prostock drag car with a mamba max 5700 0n a 3 cell lipo can go say 95-100 in 132ft will a rc12l4 pan car go about the same speed? if not how fast will a rc12l4 go with a mamba max 5700 on a 3cell lipo go? or mabe a 7700 combo on 3CELL LIPO? (that woud be bullistic) my goal is to get to 100 mph!!![>:] and it dosnt have to be in 132 feet
RE: brushless pan car
the rc12 is likly to go even faster than 100 mph because it sits so low to the ground and it is a bit lighter than a 1/10 scale. if you run a 7700 it cant take 3s lipo, it can only take 2s but i am not fully speaking from experence. look into gearing, for drag racing you can gear up if its only going at full throttle for 5-10 seconds, for more of a fun run keep gearing a little lower so you dont blow the motor/esc. to find the best layout for you get the largest,smallest, and the mid-tooth pinion and spur that will fit the car in all 3 pitches.
NJ
I can tell you this... On my AE rc10L3 touring with a 3s and 9200kv (3t trinity) I wasn't goin 100 and it took alot of messing around to even get the car to behave. I've gotten this car over 100 but, it was alot of trial and error ( not to mention money). Now the car is fitted (more like wedged) with a Neu 1515, Quark 125monter and a 4s. I have to crawl to top end... if I apply any decent juice through the power-band the car goes ape $H!T in a hurry.
Personally I think you would be better on the 1/10 platform if you are looking to power through on a direct drive pan chassis. For fun, through the 7700/3s on an awd platform! You can beat on her all day and get her there fast.
CA
Castle has the new 9,000 out where you can run 2s lipo. 5700 X 3= 17,100
9,000 X 2= 18,000
Now that I look at this I know someone is wrong..... [&:]
9,000 X 2= 18,000
WA
its kv times total voltage, now # of cells.9000 on 2s lipo wold be 66600 rpm. 7700 on 2s would be 56980rpm. the 9000 is almost 10000 rom more on 2s.
