RCU Forums
-   RC Drag Racing (https://www.rcuniverse.com/forum/rc-drag-racing-479/)
-   -   Drag racing nooby question. : / (https://www.rcuniverse.com/forum/rc-drag-racing-479/6102326-drag-racing-nooby-question.html)
lanerbrainer205 07-12-2007 11:27 AM
Ok guys, I have a few questions for you. First which is better long or short and narrow or wide? I know that weight is a huge issue in being fast as weel as wind resistance, and weight placement... is there anything else i missed? Also do small wheels get up to speed faster than big ones? I have a hige amount of more questions, but this is all I will throw at yall for now. BY THE WAY this is for a RC Top Fuel Dragster.
2916jr 07-12-2007 11:44 AM
RE: Drag racing nooby question. : /
the taller the faster to a point I will answer all of them if you need help
griz11 07-12-2007 09:52 PM
Best thing is to take a look at the rulebook first for the class you intend to run. Or check it out to decide a class where you want to run and build from there. Generally .21 top fuel cars are 29 inches have to weigh 40 some odd ounces and have a .21 motor modded or not doesn't matter. Brakes and a throttle return spring. Check www.imdra.com for the current rulebook. I had a couple of LiteSpeed rails. One was the X-21 and I upgraded that to a BioHazard. Lots of fun to run. Lots to learn to make them go fast. Direct drive cars are the deal right now. Basically a truggy rear gearset with an adapter so the clutchbell can accept a dogbone type driveshaft direct to the rear wheels. No tranny single speed. Gets rid of a lot of rotating mass to ditch the jackshaft and tranny cluster. Clutch tuning becomes more critical when you are running direct drive. You don't have a lot of gearing choices with a direct drive car as you are using the final drive only. Some use the entire plastic diff carrier some make custom mounts and run the rear pinion and bevel gear out in the air without a case around them. Brakes on those cars need to be on the rear axle so if you break a driveshaft or clutch you can still stop the car.
Griz
poe 08-07-2007 04:56 PM
With the same gear ratio, smaller tires will accelerate faster but will not have as high of a top speed.
