RC Drifting Discuss all aspects of rc drifting here!
Which
Old 12-19-2010 | 11:58 AM
Default Which
Which radio should i get for under $100 but I can get a specktrum dx2.0 for $70 canadian, So wich radio should i get?</p>
Old 12-19-2010 | 12:49 PM
Default RE: Which
You don't specify what other brands you are considering, but I would jump on the Spektrum.
I have had the 2.0, and it is a good radio. Spektrum was the first, with the 2.4 Ghz, and basically owns the market. If someone else has a 2.4, they most likely pay Spektrum for the privelege.
I run a DX3R now, and won't go to another, unless Spektrum comes out with a TX that beats it.
Old 12-19-2010 | 02:58 PM
Default RE: Which
! question do I still need to bind the Dx2.0 out of the box.
Old 12-19-2010 | 04:00 PM
Default RE: Which
ORIGINAL: teamnolimit
Bind it out-of-the-box? If you mean bindreceivers to it, then yes.
Be aware, you will only be able to use DSM1 receivers with the DX2.0. DSM2 receivers WILLNOT bind to older TX's like the DX2.0.
Old 12-19-2010 | 06:39 PM
Default RE: Which
So your saying i just need a servo to go with it and which servo is good thats $30- $40.
Old 12-19-2010 | 07:48 PM
Default RE: Which
The fastest you can afford. You may want to put a little more into that amount.
I find servos .15 or faster is good, but that is a subjective thing. I just find fast steering response a plus.
Old 12-19-2010 | 07:59 PM
Default RE: Which
how about the specktrum dx3e is it any good
Old 12-19-2010 | 08:07 PM
Default RE: Which
The DX3e is good, basement, but good. There aren't as many adjustments on the DX3e as there are on the DX2.0, but it will bind DSM2 receivers.
The choice is yours, more adjustments, or DSM2 capability.
Old 12-20-2010 | 07:49 AM
Default RE: Which
ORIGINAL: gokemidoro
Thanks for your help gokemidoro I really appreciated it, I will go with the dx3e.
