Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Drifting
Reload this Page >
Two Drifting Projects Need Help!
RC Drifting Discuss all aspects of rc drifting here!
Old 06-02-2004, 10:10 PM
mtrchamp
Default Two Drifting Projects Need Help!
I have two projects I would hope to turn into drifting cars. Here they are
The First
Traxxas Rustler
- Hummer Body, Red
- Peak 11Tx2 Motor
- Hitec Lynx Radio Gear
- Road Hawgs Tires on rear
- Stock Tires On front
- No ESC, as of now
I have lowered it so the ground clearence is about .85" I also tightened the clutch and spur gears. I also have the stock tires, Pede masher tires, and a Silverado body for it.
What do I need to turn it into a drifter?
Like what turn motor do I want?
Is it okay if it is 2WD?
What Tires should I get?
What gearing do I want? More acceleration? More Speed?
What servo should I get?
Should I get an on road body for it?
I will Post Pics of it soon and what you can see what I have done to it.
Second.
HPI Nitro RS4 3 RTR
- Stock .15 Engine
- Stock X- radial tires
- Viper Body, Red
- HT Servos
- Tx-2 Radio gear
Everything is stock
What do I need to make it a drifter?
Any info is greatly appreciated!
Old 06-04-2004, 06:27 PM
mtrchamp
Default RE: Two Drifting Projects Need Help!
Ok I tried drifting my rustler after I threw in some parts lying around so here was the setup:
XL-1 ESC
Pilot 27T Motor
Lynx Radio
1500 mAh practice pack
What should I change?? I also have a 14T motor I can put into it. Would that work better? Also, is there any way that I could get better control on the front because all I did was slide out.... like in donuts
Old 06-08-2004, 11:03 AM
t-maxx101
the rustler wont work, you just cant drift a 2wd stadium truck but the rs4 would be pretty cool
Old 06-24-2004, 03:00 PM
tourer-to-monster
Get some old wheels without tyres on and put some 53mm PVC or ABS instead of tyres on the HPI. I have done this with my Yokomo mr4 and it works perfectly, i have also tested it on a nitro car and they work like a treat.
So get drifting!!!!!!!!!!!!!!
Old 06-24-2004, 08:34 PM
mtrchamp
aight... thanks....
Old 06-24-2004, 10:25 PM
Shadow102
Hey your best bet would be a 4wd rustler or possible 4wd stampede and drift with that other wise 2wd drifting doesn't work very well and yeah 2" pvc or abs works great
