Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Drifting
 Finally Decided just need have some more questions....... >
RC Drifting Discuss all aspects of rc drifting here!
Old 02-05-2007, 12:31 AM
S m A 413's Avatar
Default Finally Decided just need have some more questions.......
i have decided to get the TT-01 kit... http://www2.towerhobbies.com/cgi-bin...p?&I=LXFSG5&P= but what radio should i get i would like something cheap and want it from tower.
also im gona put a team orion 17 turn in it what gearing should i run?
does rolling chassis mean its pretty much put to gether?
i would like some new rims for it havin any links from tower?
also would like a nice drift body links please from tower. what mm do i get? do hpi bodies fit?
and im also buying the Tamiya Aluminum Propeller Shaft http://www2.towerhobbies.com/cgi-bin...?&I=LXETM7&P=7 this will work right?
im gona try to get abs but if not pvc will do but people say its to slick what if i sand it and make it a little bit rough will it help?
thanks if you have any other things i should get let me know.
Old 02-05-2007, 12:49 AM
S m A 413's Avatar
Default RE: Finally Decided just need have some more questions.......
will this work and is it every thing i need come with it http://www2.towerhobbies.com/cgi-bin...I=LXXB01**&P=7 or http://www2.towerhobbies.com/cgi-bin...SX2**&P=M#tech wich one?
Old 02-05-2007, 12:39 PM
I have the second one works great. it comes with the reciver, and servos that you need. when you get extra cash get A ESC and the [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXBUA9&P=Z]ball bearings[/link] set there is noticable diffrence in response. I have a 19T in my TT 01 and works good for me because it makes good torque for drift and decent top end for racing.
my upgrades so far are pretty basic it drifted great stock ut I wanted a little more
fireball 19 T, Aluminum drive shaft, carbon upper frame, duratrax esc, yokomo drift tires on white 5 star Hpi wheels. and three bodys (raybrig NSX,Yokomo s 15, and hummer H2)
Old 02-05-2007, 01:54 PM
itsnotskidding's Avatar
hi dude!!..[>:]
the tt01 is a great choice, i have loads, one for drifting and my others are for crashing...lol..
all you need is bearing set, allu shaft and drift tyers, use the stock motor to start off with, this will be good so that when you get more power from your 19t motor you can use it properly!...lol
tyers are a personal choice, some say make your own, some say hpi (hard compund rubber).. yoko with, with out rings there are loads but to start with just get a set that you like the look of..lol... then experiment!
the bearing help with friction and the allu shaft will help response, the plastic stock one flex's to much and you dont get the full power through the shaft and onto the wheels,
after all that you can play a bit more, locking diffs and more.. hop-ups, but you can drift from the box 9/10 so pactice then add all the bits and bob's , you get to understand what your new parts do better and how they effect your driving, hence knowing your car better!..
hope this helps but i find it silly buying stuff and then you not liking it, after adding motors, esc, you name it..lol
the pro's will say practice makes perfect...lol...
Old 02-05-2007, 02:24 PM
S m A 413's Avatar
thanks im gona get the futaba then...
so what gearing should i run with a 17 turn motor?
and what bodies do i buy? does hpi bodies fit?
Old 02-05-2007, 08:18 PM
S m A 413's Avatar
any of these bodies work? http://www2.towerhobbies.com/cgi-bin...1&C=CHAHPI&P=0
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
