Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Drifting
Reload this Page >
HOW TO WATER DIP A NEW MOTOR!! 10 Step Guide
RC Drifting Discuss all aspects of rc drifting here!
Old 03-19-2007, 05:03 AM
jaskel
jaskel's Avatar
Default HOW TO WATER DIP A NEW MOTOR!! 10 Step Guide
Ok, here is a quick guide i made up for running in a motor using the Water Dip method;
What you will need;
Motor - DUH!!!
Plastic/Glass Container
Dishwashing Liquid
2 AA/D/C Size Batteries
Tape
Water (warmish)
Ok now lets start,
Step 1
If the motor is mounted in the car, remove it including Pinion gear (needs to not be under any load)
Step 2
Get container and fill with luke warm water
Step 3
Add some dish washing detergent to it (about 1 teaspoon)
Step 4
Join 2 batteries together with tape to form around 2.8 volts or so
Step 5
Connect the terminals to the battery, at this point make sure the motor will spin the same way as in your car, this allows proper bed in, the motor will be spinning, quickly drop in the water(if you go to slow it will spew water everywhere...lol)
Step 6, let it run fully submerged in the water( incl where the wires connect to the motor poles) for the life of the battery (DO NOT SUBMERGE THE BATTERIES IN THE WATER, this will cause a short)
Step 7
Once batteries are flat ( the water should be a horrible black colour)remove the motor and place on a rag or in Trent's case some tissues (clean ones)
Run it for 30 secs or so to get rid of most of the water, let it dry properly
Step 8
Get some WD40 or Contact cleaner or simalar electrical lube and spray a small amopunt in the can, not to much as it will spray and leak everywhere.
Step 9
Re mount back in the car
Step 10
Drift and enjoy knowing your motor is properly run in
Cheers
Jas
Old 03-19-2007, 05:59 AM
fugadude
Default RE: HOW TO WATER DIP A NEW MOTOR!! 10 Step Guide
Just curious, what is the goal in doing this? I've only breifly read about this, and I was just wondering what it does to the motor that improves its performance. Also nice guide
Thanks.
Old 03-19-2007, 06:04 AM
jaskel
jaskel's Avatar
yeah its runs the motor in properly, you will find the motor goes alot better after doing this, i used to do it on all my brushed motors for my planes and they wer so much quicker, no need with brushless.
My car goes alot better after this.
Old 03-19-2007, 08:06 AM
FireStriker
It's Break-in!,
Good Tut!
Old 03-19-2007, 01:32 PM
itsnotskidding
itsnotskidding's Avatar
hummm.. i dont know, i have never heard of this method...i will try it though, got a few motors lying around..lol
Old 03-19-2007, 03:26 PM
MEINSHNAKE
from what I hear you dont need to fully submerge the motor in the water ( I would feel alot safer with this)
Old 03-19-2007, 03:30 PM
jaskel
jaskel's Avatar
well you could do that but you will spew water everywhere...lol
Ive used this method on 10+ motors and they all scream without any problems.
Old 03-19-2007, 04:09 PM
joeyblaze
joeyblaze's Avatar
umm shouldnt u use distilled water, it doesnt conducted ?
Old 03-19-2007, 04:36 PM
driftdriftdrift
now correct me if im wrong but arent you only supposed to use this method with silvercan motors?
Old 03-19-2007, 08:37 PM
Kokopelli06
Kokopelli06's Avatar
To answer the questions, Water Dipping basically breaks in the motor. It cleans all of the dirt and grim off of the Comm and reseats the brushes onto the comm, which creates a better connection which increases speed. This only works if you FULLY dip the whole motor in the water, the water will not harm it at all.
Old 03-19-2007, 08:52 PM
Rs43EVOman
Rs43EVOman's Avatar
In which of these siutatuons do you guys use this method???
1. First breaking in of motor?
2. First breaking in of used motor, with new brushes?
3. periodically to clean the comm?
4. other (explain)?
Old 03-20-2007, 03:27 AM
FireStriker
ORIGINAL: Rs43EVOman
4. other (explain)?
All of the above,
Whenenever you feel a drop in motor performance!
Old 03-20-2007, 04:02 AM
jaskel
jaskel's Avatar
well I ran my RZ motor today after the water dip and it was running alot better, more instant power and smooth!
Old 03-20-2007, 04:03 AM
FireStriker
^^^Good news!
Old 03-20-2007, 04:35 AM
SFC K
SFC K's Avatar
Who would a thunk? I’m going to give this a try….
Nice job!
Old 03-20-2007, 06:03 AM
Rs43EVOman
Rs43EVOman's Avatar
and will regular alkaline aa's work?
Old 03-20-2007, 06:26 AM
jaskel
jaskel's Avatar
yep
