RC Drifting Discuss all aspects of rc drifting here!
I thinks it complete??!?!
Old 05-09-2007 | 04:38 PM
Default I thinks it complete??!?!
Ok so i have been posting a ton of stuff asking questions and i think i finally have all the parts i need to join the world of drifting. This is what i have......
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXHWN0&P=ML]TT-01[/link]
Lexon Scissors
Polycarbonate paint
tt-01 bearings set
Aluminum drive shaft
Futaba Reciever/transmitter/2 servos
Aluminum motor mount
Motor Heatsink
Anti-Wear grease
Running a 12t esc with Speedgem 16t double :P
and i already have batteries and charger.
I was planning on figuring out how to do the pvc over the rims.
Is that everything???
Old 05-09-2007 | 04:52 PM
GTB
Default RE: I thinks it complete??!?!
Try to find a front one-way and GET THOST PVC's!!!
Old 05-09-2007 | 05:10 PM
a front one-way???
Old 05-09-2007 | 05:23 PM
Nasher's Avatar
wouldn't the one way make it so your front won't go in reverse?( I know more about trucks so I could totally be off, so feely free to disregard anything I say)
Nasher
Old 05-09-2007 | 05:32 PM
ORIGINAL: Nasher
Nasher
Bingo. It allows the rear wheels to lock up (like an e-brake) while letting the front wheels continue spinning, so they have some grip. This lets them flick the tail out into the slide, and then you stomp on the power/ pulse it/whatever your technique and slide around the corner.
GTB
I don't know about that. A fron't one way makes both wheels turn at the same speed.
The car will act like you pulled the E-Breake on a real car.
Old 05-09-2007 | 05:38 PM
ORIGINAL: GTB
I said that... and I've used one, and that's what I did to get the slide...
Old 05-09-2007 | 05:39 PM
GTB
You posted like seconds before I did so I didn't know
Old 05-10-2007 | 01:24 AM
ORIGINAL: GTB
Oh yh. Sorry matey for any offence
Old 05-10-2007 | 03:43 AM
I wouldn't b sutre if you want a Front-oneway to start with many people just don't like it,
And can't drift with it,
So first learn how to drift and then go out and try the front-onewya![8D]
Old 05-10-2007 | 03:38 PM
I agree with FireStriker, just lock the stock diffs
Old 05-15-2007 | 07:45 AM
Lock the front and the back?
Old 05-15-2007 | 08:17 AM
infernox's Avatar
if you drift DO NOT GET A ONE WAY!!!!
Old 05-15-2007 | 09:08 AM
I like Infernox,
Striaght and to the Point!
Old 05-16-2007 | 04:24 AM
itsnotskidding's Avatar
hummmm....
if you new never put a one way in to start, i would suggest stuffing the diffs if your building the car, i would also say and it is TOTALY up to you....
get some new shocks!, i hate the stock shocks tamiya supply, i would suggest a set of carson shocks, allu, threaded, tamiya spring set fits them and are very high spec for a very cheap affordable price..
its just an idea, you buying the following and i think in all honesty the ride of the car is important, and the ride "ride's" on the shocks!..
