which motor?
RE: which motor?
between 19-23 turns work best m8 depending on ur ESC of course
most kits will drift with the standard 27turn motors as long as u use pvc or drift wheel tho [8D]
RE: which motor?
Yes, it depends how you gear it, I mean I have seen some pretty quick cars running the Silvercan motors from TT-01's hitting just on 40Kph..
It Helps to know what chassis we are dealing with in order to suggest a suitable motor...
For a HPI Sprint 2 then a Team Orion Method R 19x2T does a good job
For a TT-01 : A Epic 27T Tagged Motor will do great!!
For a TL-01 : a Tamiya TZ Motor is cool !
RE: which motor?
13t is too low for Drifting.. Drifting is not about speed... its all Torque related.
The Lowest Turn I would suggest for Drifting would be a 15x2T.. any lower and the Torque curve starts too high..
NV
RE: which motor?
ORIGINAL: magnat
i run a 5.5 brushless and 3.5 if i have to. its all depends what your setup is and where you are drifting.
NV
RE: which motor?
ORIGINAL: magnat
Brushless is different to Brushed.. Brushless offers a very wide Torque curve through out the Rev range.. Brushed doesnt'
maybe just her though.
RE: which motor?
I'm running Hot Bodies 32T S46 motor, Futaba 330CR ESC and 25T/55T Pinion/Spur. With 25T/55T, I suppose my top speed is increased but torque lowered? Anyone knows what ration can I drop to? I was told I need to change the motor posn at the motor mount if I change the ratio.
RE: which motor?
Im guessing thats on a TT then 25/55 gearing? if it is m8 try 23/58 seems to work good for drifting still nice top speed but abit more torque than 25/55
also if u mean 32turn motor u may need alower turn motor too 27t is the highest limit really for drifting most use between 17-23 for gd torque and speed...
