Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Drifting
 Will this be safe? (Motor vs FDR) >
RC Drifting Discuss all aspects of rc drifting here!
Old 03-25-2009, 10:39 PM
Default Will this be safe? (Motor vs FDR)
Specs:
4-Tec Electric
14T Fantom Motor
LPR F1 Reverse ESC
Current Gears: 84/20 (& Tranny ratio of 2.1)
FDR: 8.82 (Thanks to www.gearchart.com)
So from what ive read a few places, a FDR of about 6.5 is ideal for General RC Drifting.
Here are the ratio's that can get me that FDR...
84/27
87/28
93/30
Is it true a FDR of 6.5 is best for Drifting?
If i do go for a 6.5 FDR, then which of the 3 should i go with?
And last but not least, will it be safe for my 14T motor?
Old 03-25-2009, 11:47 PM
Default RE: Will this be safe? (Motor vs FDR)
Just an FIY...
The car was previously setup for all around speed. Since i have a 14Turn motor, which is better for speed then Acceleration.
I would like to gear for more Torque, to try and balance it out.
I read that "Lower FDR's mean more top speed, higher FDR's mean more acceleration."
So should i just stick with my 8.82 FDR with this 14T motor?
AGH.. So confused.
Old 03-26-2009, 09:09 AM
My Feedback: (18)
droppedgmc's Avatar
try it and see how it works. i run my car drift cars any where from a 6.25(current), up to 7.5. this allows for still enough torque and a little more top speed for the bigger tracks
Old 03-26-2009, 12:00 PM
I picked up some Losi Drift tires from a local hobby shop...
I played around with it a little last night but the lot was crappy.
Going to a better/cleaner lot after work today and trying it out again..
From what i notice. If i gain speed, i cant drift a turn very well.. I have to slow down a good bit, then mash the throttle to whip it out.
I'll play with it, make sure the suspension is good.. etc
If i have problems then ill get a 19T and gear it down to 6.5 DR
Old 03-27-2009, 02:10 PM
Picked up an awesome 27turn motor, going to gear it down to about 6.5FDR.... I'm excited.
But I'm fixing/replacing a bunch of other things so i'll install it then.
Old 03-28-2009, 12:06 AM
My Feedback: (18)
droppedgmc's Avatar
losi drift tires are not the best for drifting. They heat up and stick. makes you use alot of throttle
Old 03-30-2009, 02:45 PM
ORIGINAL: droppedgmc
What do you recommend for tires?
Old 03-31-2009, 12:08 AM
My Feedback: (18)
droppedgmc's Avatar
HPI T-drift, yokomo single rings, abs.
i personally love using abs tires. our home track is perfect for them. i use the yokomo's also alot
Old 03-31-2009, 12:09 AM
My Feedback: (18)
droppedgmc's Avatar
go to the vid thread or colorado thread and whatch some of our vids. most of us run abs
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
