Hell all!!! 1st time builder with chassis questions.
Hi everyone. I am a first time builder and have a few questions. I plan to build a 4wd drift car from essentially the ground up. I do plan to modify the chassis with aluminum components, but wanted your thoughts on the following chassis as a stepping stone to become a more advance builder. Keep in mind I want to make this a budget build, while learning more and eventually building a top of the line drifter for personal use. I have listed a couple chassis I have been considering below. Thoughts and suggestions are welcomed.
https://www.amazon.com/No-584-TT-02D...=1&*entries*=0 https://www.amazon.com/3Racing-KIT-S...d_sim_sbs_21_1 https://www.amazon.com/3Racing-KIT-D...VWV2DMT8E0BT2C Thanks Again |
@mateo619 Although I see no responses here would you mind sharing what you have learned since the post on your own and did you end up picking a chassis?
@Dkluch...
I am learning as I go little by litte. I am studying up on gear ratios when I have some free time. I went with a 3Racing Sakura XI Sport chassis. I have assembled the chassis and will now deconstruct to install various hop up parts I have purchases over the last couple of months. I decided on a Gool RC 3650 3100KV/4P Sensorless Brushless Motor w/ 60A ESC and a Yeah Racing Drift Spec Low Pro servo. My next purchases will be a battery, radio and esc control card. I plan on going with a Pandora Lexus Altezza body pictured here in a flat grey color. http://www.rcmart.com/images/pandora-rc-pab-167-4.jpg I have also leaned toward light buckets and purchased a few sets of wheels. I have some photos of where I am at now I will try to upload. Advice is appreciated. Thank you all. |
| All times are GMT -8. The time now is 10:11 AM. |
