RCU Forums
-   RC Drifting (https://www.rcuniverse.com/forum/rc-drifting-304/)
-   -   glue or electrical tape (https://www.rcuniverse.com/forum/rc-drifting-304/2028371-glue-electrical-tape.html)
MrWeEdYs 07-27-2004 01:50 PM
do u have 2 use glue on ABS and PVC pipes told hold or can u use electrical tape because i heard frm a freind that both will work
HPIRS4-3SS 07-27-2004 02:13 PM
RE: glue or electrical tape
just use electrical tape, its less messy
MrWeEdYs 07-27-2004 09:45 PM
thx man
CarboNeon13 07-28-2004 06:38 PM
Ok so what do I do when neither one will keep the abs on? I've superglued the heck outa my wheels, used like half a tube of modeling glue, went thru all kinds of tapes, almost considered epoxy but I want the abs to come off when it wears out...any suggestions?
Project_2501 07-28-2004 06:44 PM
CA glue? or is that what you used, there is a difference between "superglue" and CA (as far as i know)
CarboNeon13 07-28-2004 06:47 PM
i just used some good old fashioned superglue that i bought from wally world like a thousand years ago...still works, I know cuz I got my thumb stuck to the tire lol
Project_2501 07-28-2004 07:10 PM
haha
HPIRS4-3SS 07-28-2004 07:19 PM
just put more electrical tape, it wont come off if you put enough.
then when it wears out just cut it off (hack saw) it wont be very thick anymore
CarboNeon13 07-28-2004 07:20 PM
sounds like a good idea to me...as long as it works. lol, all else fails, TAPE IT UP haha
Aussie Damo 07-29-2004 12:41 AM
i had the same problem, i just wrapped a nylon/material type tape around my rims until it was hard to fit the pvc on, works great for me.
CarboNeon13 07-29-2004 02:42 AM
Yeah I tried the electric tape between the wheel and the "tire" and the fit was so tight i had to get the edge of the tire on then put it on the ground and step on it to wedge it in place...works though :D
RC-Drift UK 08-04-2004 09:00 AM
Get pipe thats about 1mm smaller than the diameter of the wheel, push the wheel in outside rim first - it will go in believe me - then 2 spots of superglue/ca/cyano/zap on one side of the wheel will keep it on
If you use too much you'll end up ditching the wheels
