e maxx drift
is it possible to drift my e maxx.
will it work |
RE: e maxx drift
probably not,
you could always try and post the video :) |
RE: e maxx drift
a little bit of negative camber on the tires, pvc or abs. it should work, seeing as the e-maxx is 4wd.
RE: e maxx drift
its kinda heavy to get real long drifts though
RE: e maxx drift
I saw someone selling pvc drift tires for maxx trucks. You can do it, you just need to experament a little. I think the pvc was for the 40 series wheels?
RE: e maxx drift
I couldnt find any onfo on drifing and emaxx, but i decided to give it a go anyway.
I bought some new savage wheels, and measured the diameter. Although they list as being 83mm, the outermost part of plastic (the bead) is actually 90mm... and you can buy 90mm stormwater pipe fittings! So, i picked up some 90mm stormwater pipe end caps, and we'll see how it goes ;) |
RE: e maxx drift
ORIGINAL: Tzi I couldnt find any onfo on drifing and emaxx, but i decided to give it a go anyway. I bought some new savage wheels, and measured the diameter. Although they list as being 83mm, the outermost part of plastic (the bead) is actually 90mm... and you can buy 90mm stormwater pipe fittings! So, i picked up some 90mm stormwater pipe end caps, and we'll see how it goes ;) |
RE: e maxx drift
probally going to have to lower it, it's very top heavy so it may flip easy, but why not?
RE: e maxx drift
me and my friend hae we just ran it on some moss and it was drifting all over the place ill try to post a vid next time ps it was all stock
RE: e maxx drift
The E-maxx will Drift, So will an E-zilla and a Kyosho Twin Storm..
If its Electric, Has 4wd and PVC/ABS Under it, it will slide.. I am yet to see a Rock Crawler drift but I have seen many Monster Trucks and Buggies Slide.. Hell Dirt Drifting is Easy with an E-zilla |
RE: e maxx drift
Dont give up on that Idea It will work. You just gotto experiment
RE: e maxx drift
true.
its all about the driver... emaxx can drift. so can a t maxx. i've seen it and i believe it. |
RE: e maxx drift
Update.... i now have some black poly pipe in 90mm... just like you use for the small wheels..
pics soon:D |
| All times are GMT -8. The time now is 07:52 PM. |
