can you drift a rs4 evo with out the conversion kit
i just sorta want to temporaraly drift
i dont want to be drifting all the time is there something easy to put on to make it drift such as tires or something? |
RE: can you drift a rs4 evo with out the conversion kit
Insulation tape wrapped tound the tyres
yep... or, if you really want to do it well, get a set of rims, and some abs... if you dont mind switching them out
so if i tape tghe tires do i tape all 4 or the back ones
and how fast should you be going into a turn to drift |
tape all 4, and speed is relative to the amount of traction you have - otherwise you crash
ABS/PE tyres last MUCH longer than tape and are far more predictable too ;) |
and.....they look cool ;)
I used to drift my Evo. I was using ABS pipe 'tires'. The tough part is balancing the weight. The back right side is going to lose traction faster than the front left, so I used shock angles and mount positions to try to compensate. (Vertical shocks are softer, outside mounting positions are softer). I also switched back to the stock tuned pipe to lose some weight on the right side. I also threw on an RS4 1-speed tranny, just to avoid dealing with the shift point. It'll work with the right setup. I smoked my buddies XXX-S round the concrete island. Nitro drifting rocks, I prefer coming into the corner sideways and doing 25 to a granny doughnut around a coke can.
| All times are GMT -8. The time now is 04:16 AM. |
