Is a HPI Pro-4 good for drifting?
Totally new to RC and im planning on getting a drifter for my Bday,
just asking if the HPI pro 4 is any good for drifting? although it doesnt come with electronics etc or should i just stick with a HPI Stage D or Tamiya TT-01? Thanks for reading |
RE: Is a HPI Pro-4 good for drifting?
yes a pro 4 can be great for drifting.... just to start off a basic setup on it would be using a spool in the rear and one way upfront on yokomo drift rims
i have never tried them myself, but from what i have heard pro 4s are some of the best cars for drifting that you can buy. while the stage d or the tt-01 are cheaper, the quality of the kits is much less than the pro 4. buying a nicer kit will help you in the long run.
Agree.
Any top racing spec kit will make a great drifter because it'll be designed to last and be efficient |
isnt it belt driven? <[:'(] and what is a spool?
nvmnd i was thinking about the sprint... but still what is a spool?b
pro 4 is shaft driven and a spool is a solid axel completly different to a differential... a diff will allow the outer wheel to turn faster to the inner wheel where as a spool will make both wheels turn at the same speed under cornering as a very basic way of putting it .... a spool is perfect for drifting in the rear anyway
ORIGINAL: *_Torque_* nvmnd i was thinking about the sprint... but still what is a spool?b |
do u have a picture of what it looks like? and where can i buy it?
http://www.team-orion.ch/news/images/hpi_pro4_spool.jpg
thats a computer generated pic of a spool without the main gear on |
the pro4 or the spool? you can buy pro4s at towerhobbies.com just type in hpi pro 4 in the search and it should come up.
no the spool.. where can i buy a spool for my tt-01?
ORIGINAL: *_Torque_* no the spool.. where can i buy a spool for my tt-01? |
| All times are GMT -8. The time now is 12:15 AM. |
