RCU Forums
-   RC Drifting (https://www.rcuniverse.com/forum/rc-drifting-304/)
-   -   getting started in drift? (https://www.rcuniverse.com/forum/rc-drifting-304/4387410-getting-started-drift.html)
slappytheclown 06-13-2006 08:12 PM
ok im new to this whole RCU thing so i hope this works
anyway,
ive been into Rc for a while and i have an older mugen seiki nitro touring car and i want to make it into a drift car and i was wondering what is needed to make it into a good drift car. it already drifts pretty well but i'd like to improve on it
any suggestions will be apreciated
thanx
ElToroLoco. 06-13-2006 10:18 PM
RE: getting started in drift?
you need pvc wheels, abs wheels, or drift rings. Those will help lots.
Neon_guy 06-14-2006 08:57 AM
Actually, on Nitro cars, I don't think ABS or PVC is going to be to your advantage because Nitro is so much faster than electric. I think you'd just slide around with little control (guess it just depends on how fast your car actually is). What mods are done to your car now?
slappytheclown 06-14-2006 01:40 PM
there is no mods on my car at all but it is fairly fast
ROYjovero 06-14-2006 01:48 PM
Just get some rubber drift ties.
Radial: Yokomo, HPI Advan, Pit Shimizu, Kawada, etc.
Slicks: HPI Stage D, Tamiya, etc.
You can run plastic tires, but you'll find out that you will have difficulty with throttle control if you have a rotary carb.
FeintMotion 06-14-2006 05:48 PM
Tweaking the suspension will help also. Im tweaking my RS4 3 evo right now. I can get about 17ft drift with the set-up I have now. Best tires are any hard slick tires. I run Tamiya slicks.
slappytheclown 06-14-2006 10:40 PM
i had an idea for rubber tires (it might work with plastic ones to)
well i skateboard and ive been told to put my wheels in the freezer to make em last longer and i thought that if you put the tires in the freezer for a few days they'll get harder and last longer
i havent tried it yet but it works good with skateboard wheels
