RCU Forums
-   RC Drifting (https://www.rcuniverse.com/forum/rc-drifting-304/)
-   -   Servo help... (https://www.rcuniverse.com/forum/rc-drifting-304/4446027-servo-help.html)
bash9127 06-29-2006 05:40 PM
Servo help...
My TT-01D came today! I'm pretty much done putting it together except for the electronics. I'm up to the point where you mount the servo. Well I'm unsure of where to mount it. It's a Futaba S3003. On the diagram it shows the servo, but it's not the same shape as mine. Does anyone have a picture or something of how yours is mounted?
FeintMotion 06-29-2006 05:53 PM
RE: Servo help...
you mount it flat on its side. The directions pretty much explains it.
bash9127 06-29-2006 06:10 PM
RE: Servo help...
But it cant lay flat on its side because it looks like this:
http://www.pyreneesmodeles.fr/catalo...duit/s3003.jpg
SJN 06-29-2006 06:37 PM
RE: Servo help...
it fits just fine :-)
Have you taken the stock control horn off the servo ?
Look in the manual, you install a servo saver instead, which is included in the kit. Just take the screw out, and pull the stock control horn off the servo splines.
When installing the servo saver, make sure you have centered the servo by connecting the radio bits together, and centered the trims on your radio.
bash9127 06-29-2006 07:59 PM
RE: Servo help...
Yeah I got it. I must have missed a page. Oops. I have it up and running. But when I turn the car on it makes a beeping noise. Is there some kind of setup I need to do? I didnt find anything in the manual about it...unless its in Japanese...
bash9127 06-29-2006 08:09 PM
RE: Servo help...
Whoa. I just tried taking it for a test drive and the thing went insane. It went full throttle into the wall then backed up full throttle into the table. I checked the throttle trim and everything. It's like it has a mind of its own..? Any suggestions as to what is causing this?
FeintMotion 06-29-2006 08:31 PM
RE: Servo help...
You need to program the ESC. Did you read the ESC Directions? Your car must have gliched becuase of how your antenna is. Post some pics of your set-up and I will help you.
Just read the ESC directions, and keep the antenna away from any electronics like the ESC.
