RCU Forums
-   RC Drifting (https://www.rcuniverse.com/forum/rc-drifting-304/)
-   -   HPI bodies (https://www.rcuniverse.com/forum/rc-drifting-304/4587199-hpi-bodies.html)
Bigrustyman182 08-05-2006 05:25 PM
HPI bodies
This might be a dumb question but id rather ask than be wrong......
Do HPI bodies fit on TT-01 chassis? Ive found multiple bodies from HPI that i love but im not sure if they will fit. Also the ones that would fit better are the 190mm right? i cant remember if its that or the 200mm
Auslide 08-05-2006 05:33 PM
RE: HPI bodies
190mm Will fit the TT-01 with new Body pole Holes.. Dont Use the HPI pre marked Holes as You will mess it up, you need to make Your own.. Do this While the Shell is clear for a Perfect fit..
driftdriftdrift 08-05-2006 05:34 PM
RE: HPI bodies
yes they fit and you're going to want to go for 190mm. just a rule of thumb 190mm electric 200mm nitro. though you can run a 200 on an electric you'll need to get some offset wheels to fit
Auslide 08-05-2006 10:31 PM
RE: HPI bodies
TT-01 will need 6mm off set rims to Run a 200mm..
HPI TE-37's
Speedway Pal Slidemasters
Kawada's all come in 6mm offset
fd3sDrifter 08-06-2006 10:30 PM
RE: HPI bodies
The wheel gap is also annoying, cuz you can only drop the body so far before it's touching the ground. I have about a 1" fender gap. This is on my TT-01.
