JDM_DRIFTER'S TT-01 MODS and R32 Body! WORKLOG
Well here's the stuff I ordered. Just some mods and the works. I installed all the aluminum parts in the rear but haven't done anything else because one of the mounting holes for the steering on the tub of the chassis got completely destroyed after I jumped my car a couple times [>:] Well I will order a new tub and show pictures then and give you guys a review on the GPM's. I also will try to paint my R32 body tomorrow.
1 *Xspeda (XSA2530) Tie rod - 25-30mm For 1/10 EP/GP USD$3.90 1 3Racing (#3RAC-N40/BL) 4mm Aluminum Lock Nuts (BK) USD$2.90 2 GPM (#STT233) Steel Universal Swing Shaft USD$19.00 1 GPM (#TT010) Alloy Drive Washer Set For TT-01 -BU USD$3.90 1 GPM (#TT021) Alloy Front Knuckle Arm Set (Blue) For TT-01 USD$10.90 1 GPM (#TT022) Alloy Rear Knuckle Arm Set (Blue) For TT-01 USD$9.90 1 GPM (#TT048) Alloy Steering Assembly Set For TT-01 -BU USD$11.90 1 GPM (#TT055) Alloy Front Lower Arm Set (BU) For TT-01 USD$10.90 1 GPM (#TT056) Alloy Rear Lower Arm For TT-01 -Blue USD$9.90 2 Intellect (#30006) Battery 3000 7.2V High-Voltage Packing Set USD$31.80 2 Sanyo (#HR-3U-4BP-2700) 2700mAh AA (4pcs Pack) USD$23.80 1 Tamiya (#50430) Calsonic Skyline GT-R Gr.A USD$25.90 2 Tamiya (#50548) 2-Piece Mesh Wheels 4WD/FWD Touring & Rally Car USD$11.80 1 Tamiya (#53672) Carbon Upper Frame For TT-01 USD$11.90 1 Yokomo (#SCR6712) Electric Speed Controller USD$32.90 W.S. Deans Male Ultra Plug (2) 1 3.59 Performance Devices 75MHz AM Crystal Set Airtronics 74 1 3.99 Tamiya On-Road Spring Set Short/Medium 1 3.29 Associated Nylon Wire Ties 4" (12) 1 1.20 Trinity Golden No Solder Leads (2) 1 4.79 Airtronics Dual Charger 110V 75mAh Z 1 21.99 W.S. Deans Male Ultra Pigtail 1 4.59 Hitec HS-475HB Deluxe Karbonite Gear BB Servo U 1 17.99 W.S. Deans Female Ultra Plug (2) 1 2.69 Great Planes Double-Sided Servo Tape 1/2"x3' 1 1.59 HPI Body Mount Pad (8) 1 3.89 W.S. Deans pair (2) 5.38 http://img.photobucket.com/albums/v4...R/DSCF2100.jpg The picture is missing two swing shafts and two GPM lower arms because I already put it in the car. [8D] http://img.photobucket.com/albums/v4...R/DSCF2089.jpg http://img.photobucket.com/albums/v4...R/DSCF2092.jpg http://img.photobucket.com/albums/v4...R/DSCF2096.jpg Ouch.. That's what i'm talking about.. The right hole broke into pieces. JDM_DRIFTER |
RE: JDM_DRIFTER'S TT-01 Mods came!
Nice man. Get a full shot of the car with all the hop ups on soon! I love putting hop ups on, it's very fun =P.
im so happy the tt-01 replacement parts are cheap, and that is some bling you got there.
Nice ride man! Cam you please post some drifting vids?
I did post vids if you looked around this forum. Anyway here's the link. [link=http://www.youtube.com/watch?v=njIrcSwhzLw]CLICK HERE[/link]
ORIGINAL: bykeking Nice ride man! Cam you please post some drifting vids? |
You should have ordered a new TT01 so the parts can look even better.
Cool |
Why would I do that? I have a tt-01d so buying another tt-01 is a big waste in money.. I can buy new chassis parts and keep my drivetrain and that would be cheap but why bother? It will get messed up again anyway! The bottom of the chassis scraps the ground with the soft shocks I have.
ORIGINAL: FeintMotion You should have ordered a new TT01 so the parts can look even better. Cool |
I have heard some of the GPM parts can be Dodgey but I will find out from your experince as to if it is true or not...
I installed GPM on the rear and they fit perfectly. The parts are also very light considering they are aluminum so there isn't much of a weight difference. At first I wasn't going to buy them until one of my front uprights snaped..
ORIGINAL: magnat I have heard some of the GPM parts can be Dodgey but I will find out from your experince as to if it is true or not... |
RE: JDM_DRIFTER'S TT-01 MODS! WORKLOG
Well this is what I did the past couple days.
Finished the R32 http://img.photobucket.com/albums/v4...R/DSCF2111.jpg http://img.photobucket.com/albums/v4...R/DSCF2113.jpg http://img.photobucket.com/albums/v4...R/DSCF2114.jpg Soldered all deans http://img.photobucket.com/albums/v4...R/DSCF2107.jpg Dissable my chassis and waiting for my new tub! http://img.photobucket.com/albums/v4...R/DSCF2108.jpg -JDM_DRIFTER |
hey jdm, very nice r32 , do you do all your work on the dryer?
A lot of GPM - Keep us posted... Want to see some video's when you're done.
As for my TT-01 - my bearings arrived in the mail today. Sometime next week I will put it all together. |
Mostly. It only sucks when I drop parts and they roll under the dryer [>:] lol
ORIGINAL: celica_racer09 hey jdm, very nice r32 , do you do all your work on the dryer? |
Yeah I would glady keep you all posted.I will make a R32 video for sure when it's all done. Bearings are the way to go [8D]
JDM_DRIFTER ORIGINAL: studysession A lot of GPM - Keep us posted... Want to see some video's when you're done. As for my TT-01 - my bearings arrived in the mail today. Sometime next week I will put it all together. |
Here's some more of my progress. I put it all together already but I didn't recieve my new tub yet so the steering linkages are still on hold. I also atached my Tamiya two piece rims to abs.
-JDM_DRIFTER http://img.photobucket.com/albums/v4...ddER/r32x4.jpg http://img.photobucket.com/albums/v4...ddER/r32x6.jpg http://img.photobucket.com/albums/v4...ddER/r32x2.jpg http://img.photobucket.com/albums/v4...ddER/r32x3.jpg http://img.photobucket.com/albums/v4...ddER/r32x5.jpg http://img.photobucket.com/albums/v4...ssiscarbon.jpg http://img.photobucket.com/albums/v4...r32rearwin.jpg http://img.photobucket.com/albums/v4...ER/wingr32.jpg http://img.photobucket.com/albums/v4...R/DSCF2118.jpg |
Now I am stripping the nasty looking black enamel off using rubbing alcohol and bleach and I'm giving it a good 24 hours to soak.
http://img.photobucket.com/albums/v4...R/DSCF2188.jpg |
I missed something -
Black enamel on what? |
ORIGINAL: studysession I missed something - Black enamel on what? |
That's right. The black enamel turned out nasty so i'm gunna go out sometime to the hobby store and get Tamiya TS paint.
ORIGINAL: aer-wubby ORIGINAL: studysession I missed something - Black enamel on what? |
Looks good, but IMO it's a waste of money. Could've gotten a better chassis for all the money invested.
I could have but I didn't ;) I don't need anything to fancy for drifting BTW and I just bought aluminum parts because they are more reliable.
ORIGINAL: aReOhwhY Looks good, but IMO it's a waste of money. Could've gotten a better chassis for all the money invested. |
Aluminum parts tweak, meaning permanent changes to suspension geometry. It you kept using plastic parts, you can just replace them.
ORIGINAL: JDM_DRIFTER I could have but I didn't ;) I don't need anything to fancy for drifting BTW and I just bought aluminum parts because they are more reliable. ORIGINAL: aReOhwhY Looks good, but IMO it's a waste of money. Could've gotten a better chassis for all the money invested. |
Replacing plastic parts aren't acually cheap.. I had to replace a plastic upright but doing so means that it will come with the whole set of parts.. Parts I don't need and the price comes out to $8 and I only needed one part! That's why I bought aluminum and I don't see any problems.
ORIGINAL: aReOhwhY Aluminum parts tweak, meaning permanent changes to suspension geometry. It you kept using plastic parts, you can just replace them. ORIGINAL: JDM_DRIFTER I could have but I didn't ;) I don't need anything to fancy for drifting BTW and I just bought aluminum parts because they are more reliable. ORIGINAL: aReOhwhY Looks good, but IMO it's a waste of money. Could've gotten a better chassis for all the money invested. |
Looking good. You should have eliminated as much of the wiring as you could have tho, when you installed eans.
| All times are GMT -8. The time now is 07:02 AM. |
