RCU Forums
-   RC Drifting (https://www.rcuniverse.com/forum/rc-drifting-304/)
-   -   DRIFTING (https://www.rcuniverse.com/forum/rc-drifting-304/4635475-drifting.html)
FAST4-TEC 08-17-2006 04:09 PM
DRIFTING
sup u all !
will i am new here.. not new to nitro ! will just bought a 3.3 4tec and i want to drift.. but the car doesnt seem to do a whole drift.. i was wounder what tires are good to drift... ????
will thanks
for the help
aer-wubby 08-17-2006 04:21 PM
RE: DRIFTING
Yokomo makes drift tires, but for a budget tire - get either ABS or PVC plumbing pipes and cut them to width of your rims.
FAST4-TEC 08-17-2006 04:36 PM
RE: DRIFTING
ORIGINAL: aer-wubby
ok so yokomo tire are this right ? http://www2.towerhobbies.com/cgi-bin...?&I=LXLTV0&P=7
also will they last for a long time or should i go with ABS?
also do u have a link of a ABS pipe so i know what to look for... like i say i am new to difting...
aer-wubby 08-17-2006 04:40 PM
RE: DRIFTING
Those tires could work, I heard Yokomo makes very good ones. ABS is just the material of plumbing pipe you can find at hardware stores. It's black, and people say it's better than PVC both in longetivity and sliding. ABS is always cheaper than special tires you buy.
FAST4-TEC 08-17-2006 04:45 PM
RE: DRIFTING
ORIGINAL: aer-wubby
oks then on more question and i should be done...
should i do front and rear... or should i just do rear...
i am going to go with ABS.. seen it cheaper to buy...
THANKS ALOT DUDE!
bykeking 08-17-2006 04:46 PM
RE: DRIFTING
Front and rear.
FAST4-TEC 08-17-2006 04:48 PM
RE: DRIFTING
OK THANKS !
on yeah... what then normal size to get the ABS.. 4 the rims ?
GraTou 08-17-2006 05:20 PM
RE: DRIFTING
3.3 N4tec to me seems too much power for drifting lol.
you dont want to break the engine by overheating it?
FYI- dont use abs on nitro, you will overheat.
I suggest some rubber drifting.
HPI stage-D or Tamiya Type D tires.
hpi- http://www2.towerhobbies.com/cgi-bin...?&I=LXKSC3&P=7
tamiya- http://www2.towerhobbies.com/cgi-bin...&I=LXLVZ0&P=ML
kelvonlove 08-17-2006 06:10 PM
RE: DRIFTING
yup Gratou's right....you'll want to buy the hpi drift tires...i have them on my nitro and they are perfect...they dont wear too bad either....i had abs tires on at first and i burnt some servos and such...i put the hpi's on my electric and i work really hard to drift and my battery didnt last as long....so in short....electric=abs nitro=hard compound stage d tire
kelvonlove 08-17-2006 06:12 PM
RE: DRIFTING
and when i was drifting with the abs on my nitro...my engine degree was in between 309-340 and that is NOT GOOD
aer-wubby 08-17-2006 06:23 PM
RE: DRIFTING
ORIGINAL: kelvonlove
Ouch =X.
FAST4-TEC 08-17-2006 06:33 PM
RE: DRIFTING
ORIGINAL: GraTou
does this tamiya come with the rims too ?
aer-wubby 08-17-2006 06:41 PM
RE: DRIFTING
Yes.
FAST4-TEC 08-17-2006 07:00 PM
RE: DRIFTING
ORIGINAL: aer-wubby
Yes.
THANKS FOR ALL U GUYS HELP ! !!
GraTou 08-17-2006 08:02 PM
RE: DRIFTING
Did the glow plug fly out? lol.
That is wayyy too hot.
